Stepped on clutch pedal and now cruise control flashes
Old Aug 13, 2013 | 10:44 AM
asand1's Avatar
Driving down the highway with cruise on, I stepped on the clutch pedal and the cruise control light started flashing. I have the "cruise always on" mod.
There is a wire replacing the relay, so it's not a bad relay.
I suspect the clutch switch or rubber bumper on the pedal. I will post what I find after work.
Any advice would be appreciated.
Old Aug 13, 2013 | 10:48 AM
Amerikaner83's Avatar
My guess is the rubber bumper thing.
Old Aug 13, 2013 | 11:01 AM
Aflion's Avatar
If you have it to where it's always on, isn't it supposed to do that? When I have it on and press the clutch in, mine flashes. Not sure if it's supposed to do that or not, though.
Posted from Maxima.org App for Android
Old Aug 13, 2013 | 12:37 PM
asand1's Avatar
Its never flashed in three years. The button is always lit, and the word cruise is lit only when active.
While cruise light was flashing on the whole drive in, the system was unresponsive.
Old Aug 13, 2013 | 12:56 PM
asand1's Avatar
Ok, tje platic bumper and switch are intact, so i'll have to investigate further after work.
Old Aug 13, 2013 | 03:18 PM
Climaxx's Avatar
Happens to me when I put mine in neutral when cruise is on. I just turn cruise off then back on. Not sure how you guys with this lazy mod would fix it.
Old Aug 13, 2013 | 03:49 PM
njmaxseltd's Avatar
Originally Posted by Climaxx
you guys with this lazy mod.
Lets not hold back now...
Old Aug 13, 2013 | 04:45 PM
asand1's Avatar
I put the ASCD relay back in before driving home from work for the ability to reset the system while driving home. The issue did not come up again. Hopefully its not intermittent, and just a fluke.
Old Aug 13, 2013 | 11:11 PM
DennisMik's Avatar
According to the FSM, the cruise light blinking is usually associated with one of the inputs on the control module missing power. Since you said this happened when you stepped on the clutch, this would mean pin 5. The power flow is fuse, energized relay (or the jumper), through the clutch pedal switch, through the brake pedal switch, to pin 5 of the control unit.
I used the FSM and looked at pages EL-137, EL-140, EL-142, el-145.
Or it could be that the control unit just needed to be powered off and reset.
BkGreen97
Apr 2, 2016 05:47 AM
Smackasmith
Feb 1, 2016 12:40 AM
JoshG
51
Sep 21, 2015 10:41 PM
ef9
Sep 10, 2015 10:35 PM
intimidator
Sep 5, 2015 07:23 PM
