Installed new Cattman Y pipe...Rattles, thing sucks..
I just had my Cattman Y pipe installed yesterday. Right when I start up the car it rattles like it is hitting something. The sound is really annyoing and it makes my Maxima sound like a POS. I took it back to my machanic, after the problem and he couldn't figure it out. I know it is not his fault because he has already installed 6 or 7 of them. If this continues this Y pipe will be for sale because I can't stand this sound. Also, when I'm accelerating slow it vibarates and shakes everything in the car.. The steering wheel the most. Does anyone know what this problem could be or know I could fix it? Thanks..
Originally posted by Nealoc187
Seems to me like people who "had them installed" have problems and people who did it themselves have none, me included.
I could have sworn you had 2 unidentified master maxima mechanics helping you, one with a name starting with a B and ending in rian...and the other starting with an S and ending in zymon.
I was going to buy the Cattman today, now I am concerned.
It was between the Cattman and the Stillen. I heard the Stillen had a flange issue, so I was going with the Cattman, for better finish and gains.
Who knows, I will probably take a chance on the Cattman.
Get the cattman, and install it all by yourself like I did
now say it with me "ONLY MASTER MAXIMA MECHANICS CAN INSTALL Y-PIPES!"
how long
FYI...I'm going to put in a Pacesetter STS at the same time I put in the Y-pipe for convenience reasons.
FWIW, my Stillen ypipe rattles also...but only recently. Funny how it only happens when I make a left turn or stomp the gas.
It's been on the car for about 2 years with no issues. No regrets but I think I need to get it adjusted.
Jim
Jim
Re: ECU
Originally posted by DCmax
RESET THE ECU. I had the same problem when I installed my Cattman about a month ago. I reset the ECU and everything was peachy.
Re: Re: ECU
Originally posted by BriGuyMax
why would the ECU have ANYTHING to do with his problem?!?!?!?! He has a vibration because the y-pipe is hitting something....it's probably hitting the heat shield that you are supposed to REMOVE when you install an aftermarket y-pipe...and the muffler shop probably didn't remove it.
So before you knock my suggestion, why dont you give one of your own before declaring yourself a master mechanic. There's nothing master about hyping the Cattman on a thread where someone is obviously having problems with it.
Still confused as to why resetting the ecu would have anything to do with the vibration that's being experienced.
Other members have experienced this hard idle and more times then not, the problems have stopped after a simple clockwise turn of a screw.
I dont have the background to divulge into what in fact the ECU does and how it calculates the fuel to air ratio and anything like that, wish I could. Maybe someone else can weigh in.
Originally posted by CitrusSpeed
where is this little screw i am turning at?
www.maximadriver.com
Go to the How2s section and click RESET THE ECU
Re: Re: Re: ECU
Becuase, I had THE SAME PROBLEM, from the SAME BATCH of CATTMAN y pipes. I too had a problem with the vibration and the section of the pipe after the flex was touching the frame on my car so initially I though it was that. The pipe was just touching though and there was no stress whatsoever being put on the frame. SO, before I decided to get the car back on a lift, and with suggestions from people on this board, I decided to reset the ECU which takes all of 2 SECONDS to do.
I DID GIVE A SUGGESTION...why don't you re-read my other post. oh, and about the master mechanic thing....do you know what sarcasm is??
Re: Re: ECU
i will be getting the cattman again because from my prior experience the pipe fit perfectly and provided AMAZING gains. Y don't i go the cheaper route? do a search for the comparison in pipes. You get what you pay for in my opinion.
After I had my Cattman installed I was getting all kinds of rattling. It turn out that the b-pipe was hitting the car. Also the 2nd down (toward the back of the motor) there is a heat shield that was vibrating against the the pipe so I bent it away and no noise.
Originally posted by GTRBlkMax97
Thats why I am going to install mine
Originally posted by puremax
For the 20th time! The person who installed the Y pipe works on Maxima's almost everyday for hours. Wasn't his fault, he has installed about 7 of them already.
I had an annoying rattle after installing my Cattman pipe (myself) as well. Turns out it was one of the old mounting brackets that was rubbing the pipe. I removed all the old brackets (which were not being used anyways), so now the Ypipe is supported only from the two exhaust manifolds and at the cat. Rattle is gone and pipe works fine now.
VQ'ed
69
Aug 27, 2020 12:29 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
Greenmaxspeed
Aug 31, 2015 09:06 PM
kirkhilles
Aug 8, 2015 10:53 AM
