Need advice quick......
Old Jan 15, 2002 | 07:37 PM
97MaxSE's Avatar
Today I tried to take off my filter to install my pop charger. I got 3 of the 4 screws off. Then I couldn't get the 4th one off. So I tried to put the other 3 screws back on but they wouldn't go back in. My filter is still connected just w/ out 3 of the screws. I need some advice on what to do. How much would it cost to take it somewhere to get my pop charger installed? Help me out here.........any advice will help.
Old Jan 15, 2002 | 07:47 PM
Maxilicious's Avatar
Re: Need advice quick......
Why could you not get the screw off. Was it the bottom one on the inside?
Old Jan 15, 2002 | 07:53 PM
97MaxSE's Avatar
Re: Re: Need advice quick......
no the top right.....cause I could not get my socket wrench over it.....not enough room....I stripped the hell out of it too
Old Jan 15, 2002 | 07:56 PM
do you have a regular 10mm hand wrench? That is what I used
WaarrEagle's Avatar
Re: Re: Re: Need advice quick......
Use an open ended wrench. It worked great for me. I think its 10mm.
Old Jan 15, 2002 | 08:29 PM
97MaxSE's Avatar
Re: Re: Re: Re: Need advice quick......
What is an open ended wrench......
Old Jan 15, 2002 | 08:35 PM
95emeraldgxe's Avatar
its a wrench that is like silver.......one side is a circle the other side is like half a circle
Old Jan 16, 2002 | 12:11 AM
blackmaxED's Avatar
Use a phillips screwdriver
If the six sides are stripped, use a phillips, mine had it.
Old Jan 16, 2002 | 03:58 AM
KWheelzSB's Avatar
Spray the bolt at both ends overnight or a couple hours b4 you work on it w/ some WD-40 or equivalent. You should be able to get past this minor roadblock without paying a shop.
If you need more help, holler back - someone here will be able to help you on this, 4-sure.
Good luck!
Old Jan 16, 2002 | 06:36 AM
97MaxSE's Avatar
...........help.....
Good luck!
There is this box in the way of the screw. This is the only reason that i can not get the screw off. If you have a 97 you will see what I am saying. Please keep feeding me more info. Thanks.
Old Jan 16, 2002 | 06:43 AM
HondaKiller718's Avatar
Use a small pair of pressure pliers or something to get that out. May the force be with you!
Mahmuth
Aug 16, 2024 08:23 PM
gigabyte
Jan 6, 2017 06:05 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
dshinn
Sep 26, 2015 08:07 PM
