what is a heated oxygen sensor?
Old Aug 23, 2013 | 06:12 PM
gruesome's Avatar
I have three codes for two oxygen sensors. They mention heated . Is that a special kind of oxygen sensor?
Old Aug 23, 2013 | 09:19 PM
DennisMik's Avatar
the engine uses 2 kinds of oxygen sensors, non-heated and heated. I wouldn't call it special as all engine makers, not just Nissan, use both kinds. The heated oxygen sensor is after the catalyst. The non-heated is used before the catalyst.
The O2 sensor that is before the catalyst is called the upstream sensor while the O2 sensor after the catalyst is called the downstream sensor.
Old Aug 23, 2013 | 09:45 PM
BenL's Avatar
I thought our Maximas used only heated o2 sensors (positive, negative and reading wires on all of them)?
IIRC non-heated are typically 1-wire sensors
Old Aug 24, 2013 | 06:51 AM
gruesome's Avatar
The two bad ones are three wire, wasn't sure if they meant a special kind instead of three wire. Thank you for the help.! :-)
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
zmcneely13
Sep 26, 2015 02:26 PM
