help with headers!
Old 08-29-2013 | 09:10 PM
MaxStock's Avatar
help with headers!
Anyone know if cattman headers will mate with a warpspeed y pipe???
Old 08-30-2013 | 08:55 AM
Nope.
Old 08-30-2013 | 09:38 AM
Max_Gator's Avatar
I don't see why they wouldn't. The y mates to the original exhaust manifold so it should mate to the headers.
One thing to be aware of if you are installing the headers, at least in the version I have, is that you have to tighten things down in stages. Basically, try to get everything loosely assembled, then tighten down.
It can be a real pain in the ***.
Old 08-30-2013 | 04:47 PM
JSutter's Avatar
I'm nutty for Nissans
Not even close. Aftermarket Y pipes bolt to the stock manifolds. Cattman headers are longer and you need to use the matching Y.
Old 08-31-2013 | 08:45 PM
Zach-R's Avatar
Only headers that fit aftermarket y pipes are the xs power/eBay shorty headers. I have them paired with a budget Y and noticed a small increase in power via the butt dyno. However I'd recommend getting at the least obx v2 headers or better. Wish I'd had.
Old 09-02-2013 | 07:30 AM
Max_Gator's Avatar
Guess I'm off then. But what I dont understand is that my cattman y fit the stock manifold. Then I added the Cattman headers. And they fit.
So, how did the cattman y fit the stock manifold?
Old 09-02-2013 | 10:01 AM
JSutter's Avatar
Are you sure you don't have Stillen headers?
Old 09-02-2013 | 02:16 PM
maxfever1987's Avatar
If you installed a CATTMAN y pipe and it fit to stock manifolds and than you added headers which also fit the same y pipe than you do not have CATTMAN headers, those headers are only and only able to fit with the supplied y pipe,
Old 09-02-2013 | 02:20 PM
These are CATTMAN headers
https://www.google.com/search?hl=en&...S-s9vvozQNM%3A
Old 09-03-2013 | 07:04 AM
Max_Gator's Avatar
I have cattman for certain. Been in my sig for years.
And I'm absolutely certain about the installation since I did it all myself.
Edit - just realized this is 4 th gen. Mine are on my 2k. Perhaps that is the difference.
Old 09-03-2013 | 08:26 PM
JSutter's Avatar
Cattman headers are for 95-03. They are all basically the same animal. There have been a few different designs over the years. Still, none work in conjunction with a stock replacement Y. Only shorty headers work with a separate Y. Stillen made a short production run, the rest have been SS Autochrome or XS Power and their knock offs.
Old 09-04-2013 | 06:39 AM
Max_Gator's Avatar
Then my memory on installation must be wrong. I know I had the y first but guess I must have replaced it when I got the headers. Weird. I usually remember that stuff. Must be old age!
KabirUTA13
19
10-17-2015 03:15 AM
Socalstillen
09-26-2015 01:01 PM
ac max 92
09-17-2015 08:35 AM
Maxboy23
09-04-2015 07:04 PM
Quick Reply: help with headers!
