Is it okay to run with out power steering?
Old Aug 30, 2013 | 03:21 PM
miho1269's Avatar
97 nissan maxima gle. Power steering pump is making alot of noise and has a real bad wobble to it. Is it okay to run without power steering belt or is it gonna make it impossible to drive. Just need to go a week or so until i can replace the pump.
Old Aug 30, 2013 | 03:34 PM
RA030726's Avatar
I'm nutty for Nissans
You'll be ok but stopped or at parking lot speeds turning will be a workout.
Old Aug 30, 2013 | 04:33 PM
chrome91's Avatar
you can run without it, but as said when youre trying to back out of a parking spot its gonna be a bear to turn the steering wheel. by the end of the week your arms are gonna look like Popeyes lol
Old Aug 30, 2013 | 04:50 PM
rayrobot's Avatar
Lol i have no power steering in my dsm talon. Everything is good except parking. Parking is a *****.
Old Aug 30, 2013 | 04:53 PM
njmaxseltd's Avatar
The ca will be vey hard to turn, that does impact the safety factor, especially if your driving around town.
Old Aug 30, 2013 | 05:00 PM
2naboy's Avatar
Power steering is only needed when the car is at a standstill (or at really slow speeds). Once moving, power steering is no longer necessary and the steering can feel normal and safe. The only concern will be with the rack and pinion over time. Depending on the design, a power steering rack and pinion may wear out sooner when their is no power assist. I have driven manual r&P and actually have an mr2 that came with a manual r&P, you get used to it over time.
Old Aug 30, 2013 | 05:08 PM
Get swole for a week. YOLO.
Old Aug 30, 2013 | 09:51 PM
DjHackStyle's Avatar
Cut the power steering belt off and drive for a week when u get the pump put a $10 new belt. They have to take the belt off to put the pump so the extra cost is only the belt which is like $10
Old Aug 31, 2013 | 06:45 PM
miho1269's Avatar
Thanks for the info. Best response from a forum ive ever been a part of for a noob-ish question.
Old Sep 18, 2013 | 08:36 PM
miho1269's Avatar
Turns out crank pully seperated and the outside slot or whatever over lapped the inside slot and ate both belts at once.
Old Sep 18, 2013 | 09:03 PM
Ouch. Crank pulley failures are common these days.
Old Sep 18, 2013 | 11:57 PM
deloa84's Avatar
Yes they are. Had to replace mine because it made my car basically a vibrator on wheels haha
Old Sep 19, 2013 | 03:31 AM
max ride 41's Avatar
not to thread jack but what crank pulley did you use?? i was looking at an underdrive pulley from ebay cause mine is wobbling pretty rough, thanks
Old Sep 19, 2013 | 07:24 PM
miho1269's Avatar
Id like to know too because im about to go to o'riellys and blow 200 on an OEM replacement
Old Sep 19, 2013 | 07:41 PM
T_Behr904's Avatar
Having a disconnected power steering rack is different than driving a car with a manual steering rack. You can run with it disconnected, but you're gonna fight it trying to turn it tight while parking driving at low speeds. The remaining fluid inside your steering rack will also work against you since it's not being pumped thru. If you have another car to drive until you can get your Max repaired, i'd recommend doing that.
Old Sep 19, 2013 | 07:49 PM
miho1269's Avatar
Well a couple posts up i already put that the pump isnt the problem the crank pully failed. Thanks tho.
Old Sep 19, 2013 | 09:30 PM
Old Sep 20, 2013 | 07:26 AM
T_Behr slippin'.
Old Sep 20, 2013 | 06:59 PM
T_Behr904's Avatar
T_Behr slippin'.
Whoops...
Old Sep 20, 2013 | 11:52 PM
deloa84's Avatar
I actually got one from a local near me. He has a 5th gen in which he was swapping out a blown motor and he sold me the crank pulley to me for cheap. The crank pulleys from 1995-2001 should work on yours.
pkfinn
Jan 3, 2016 02:55 PM
iflexsteel
Sep 15, 2015 03:37 AM
magneto112
Sep 10, 2015 12:52 AM
hydriplex
Aug 28, 2015 02:13 PM
Mrbizness1
Aug 18, 2015 08:43 PM
