View Poll Results: How many AZ Alternators have you been through?
50.00%
14.29%
3 or More
35.71%
Voters: 14. You may not vote on this poll
Poll: Autozone Alternators
Old Sep 3, 2013 | 06:24 AM
aackshun's Avatar
How many have you had?
Just post any comments on your experience relative to AUTOZONE brand alternators only please, k-thanks.
Old Sep 3, 2013 | 08:52 AM
DennisMik's Avatar
Bought and installed 08/03/2009, approx 45K miles ago.
Old Sep 3, 2013 | 11:20 AM
schmellyfart's Avatar
July 2012 I bought a reman that was DOA (generic alt), exchanged it for another reman (nissan alt) and have been rocking it since.
Old Sep 3, 2013 | 01:25 PM
aackshun's Avatar
^ So that counts as two
Old Sep 3, 2013 | 02:12 PM
Originally Posted by aackshun
How many have you had to exchange?
Looks like one to me.
Old Sep 3, 2013 | 04:40 PM
tosheto's Avatar
Bought VQ35 alternator and put it in my VQ30DE-K. 2 years with no issues at all.
Old Sep 3, 2013 | 06:18 PM
maxfever1987's Avatar
Bought a autozone alt in 08 and it went on me last moth, so exchanged it for another one, pretty good for 5 years
Old Sep 3, 2013 | 07:19 PM
Trini Boom's Avatar
I went through 3 of which the first replacement had bearing/noise issues. Swapped it out for another and it worked for 8 months and then the brake and battery light were intermittent but it passed charging tests..after that the outer aluminum casing broke off so I swapped it. Then I just didn't leave the third one on long enough so went back to Reman OEM.
Old Sep 4, 2013 | 01:39 AM
Climaxx's Avatar
Went through 4 in a 2 month period. Said **** autozone and went to napa. Now I only have to replace them every 6 months or so.
Old Sep 4, 2013 | 07:24 AM
tosheto's Avatar
^ WTF do you do with those tings to go out so often?
Old Sep 4, 2013 | 07:39 AM
aackshun's Avatar
You know the sad part is, mine have only lasted a few hrs of running time, recently I have been swapping motors and drive the car around and take the motor back out and not use the alternator for awhile.
The longest lasting one I had was the Alternator I brought used from a Junkyard, about 5 months.
Old Sep 4, 2013 | 07:47 AM
AznRyan's Avatar
Salvage yards FTW - Got a $200 part for $5
Haven't had to replace the alternator in my Infiniti yet, though
Old Sep 4, 2013 | 05:38 PM
Climaxx's Avatar
Dude I wish I knew... it's annoying really..
Old Sep 5, 2013 | 06:06 AM
aackshun's Avatar
For future clarity I edited the first post.
If the first alternator you purchased from Autozone worked, pick one.
If you have had one DOA and then they exchanged for another that's two!
Also, always have them check it out of the box, it's happened to me at least twice where they open the box and it tested out bad.
Old Sep 5, 2013 | 10:37 AM
DennisMik's Avatar
If their alternator testing is anything like their starter testing, don't waste your time having it done.
Old Sep 5, 2013 | 11:04 AM
L_U_D_I_AMaxima's Avatar
haven't taken apart the maxima alternator yet, but on most hondas and toyotas all you have to do is replace the brushes which you can buy for about $12 online and your alternator is charging better than ever... that is if you brushes are worn out... I did rebuild my Accord alternator for $12 and 50K later when I sold the car it was still charging like new...
Old Sep 5, 2013 | 12:02 PM
I can't change my poll answer
Old Sep 7, 2013 | 05:43 PM
RA030726's Avatar
I'm nutty for Nissans
7/24/2006
Still going
Old Sep 7, 2013 | 08:54 PM
Reality sucks's Avatar
#1 lasted for 6 weeks
#2 lasted 2 minutes, locked up, ate up belt
#3 lasted six months, headlights very dim
#4 Used OEM From yard, 2 years strong. Used OEM over re-man any day.
Old Sep 7, 2013 | 09:35 PM
TravisCadello's Avatar
installed one in my 95 put 25k miles on it sold it never 1 issue,installed one in a customers car and started it turned headlights on bulbs were SUPER BRIGHT then one popped checked voltage was pumping out over 15volts! took back got another and not a issue since, my 2001 got a autozone alternator 10k miles ago and is still good.
all in all its pretty good cause I've used the same warranty phone number for all 3 vehicles and only paid once haha fac autozone.
Old Sep 8, 2013 | 06:18 AM
jholley's Avatar
I installed an autozone remanufactured alternator on a 97 two summers ago for a friend and it's still working.
I got the alternator installed for free in my 98 back in 2002 during the recall and it has held fine.
Old Sep 8, 2013 | 08:07 AM
Climaxx's Avatar
Originally Posted by jholley
I got the recalled OEM alternator installed on my 98 back in 2002 and it has held fine.
Why do you have a recalled item in your vehicle? Doesn't sound to smart especially when it's a free replacement from the dealer.
Old Sep 8, 2013 | 09:07 AM
jholley's Avatar
You're right items that are recalled are free.
Old Sep 8, 2013 | 01:59 PM
Climaxx's Avatar
Okay that's better lol
Old Sep 9, 2013 | 06:41 PM
Nealoc187's Avatar
SLOW
i've had 2 or 3 of them, only problem i ever had was an install problem. can't remember what the issue was as it was like 10 years ago, but for some reason i was unable to install it because of a physical issue that prevented it.
Old Sep 9, 2013 | 06:49 PM
Crusher103's Avatar
I think most issues on here are the actual install of the alternator not the alternator itself plus grounding. I have one on my car and i have no issues with it. Guys check your grounds and dont make the alternator work overtime because of shat grounds.
Old Sep 10, 2013 | 01:12 PM
Jaehblue3's Avatar
The initial I purchased from them lasted two days. Exchanged it for another one that lasted about two years before the bearing failed on it. On my third one now in 4 years
TallTom
57
Oct 14, 2025 05:16 PM
