Parting out '99 Max; have '98 Max - what to save?
I have a '99 SE Limited Max that was in a front end accident (200K miles). I bought a replacement '98 SE (85K miles). I have grabbed a few items off the '99 and installed them on the '98, but now it's time to part it out and then scrap it. I don't want to stockpile stuff for no reason, or keep stuff that's likely to be junk at 200K miles, but I figure there may be a few items that would be pricy to replace that I should hold on to.
What would you save off the '99 if you were doing the same? Keep in mind the 200K miles in the Northeast ... it's very rusty underneath.
I would def save major components like the a/c compressor, alternator, starter, condensor, radiator, etc.
also things from the engine like coil packs, injectors, spark plugs. those are always great to have extra laying around.
So your 99 SE limited had perforated leather and gold tinted SE wheels? Swap 'em out dude!
Nice find on the 98 SE with 85K miles...stickshift?
While gutting the 99 SE I would also take (if so equipped);
gage cluster
auto-climate control unit
Entire Bose system (HU, amps and speakers) PLUS the harness.
SE Limited floormats
Both axles still good (boots intact?) Maybe get those too.
Many of the things if you don't use them can be sold here on the org.
It would be such a shame if that SE limited was red. With the black perforated leather that was THE most unique 4th gen Maxima.
gage cluster
gage cluster
gage cluster
It has the perforated, but unfortunately there's a small tear in the driver's seat and some of the vinyl on the side is slightly damaged, so I kept the lower mile leather in the '98. Could be fixed by someone who really wanted the Limited interior.
When you say "plus the harnass" on the Bose, is there a section that disconnects in the dashthat is unique? Or are you suggesting thefull harnass complete with speaker wiring, etc? Is there an amp somewhere for the speakers or does it all drive out of the head unit?
Wheels are titanium. Could use a touch up but I'll be keeping those . The newer car came with standard silver... those will likely go out for sale.
...When you say "plus the harnass" on the Bose, is there a section that disconnects in the dashthat is unique? Or are you suggesting thefull harnass complete with speaker wiring, etc? Is there an amp somewhere for the speakers or does it all drive out of the head unit?.....
You should get the Bose HU and the 4 speakers with the amps. They're mounted together so when you take a speaker out, the amp comes out with it. Plus, you should get the wiring harness that connects them all together. It is unique...that skeleton goes from the Head Unit dash to each front door and under the carpeting to the rear speakers. If the 98 has Bose then no biggie, but I'm sure you could sell the entire system to someone on the org. The Bose system in the 4th gen was very good.
If you seriously need those vent parts, PM me your address. I pulled the center console out already and I think the vents are still intact. The outer surface is junk (wood grain issues) but the vents were OK and I think they came out intact. Let me know how much you of it you need and I'll cut you a deal you can't beat.
How do the axles look? Are the boots torn? I have a 95 auto both sides are in bad shape, I would pull the throttle body, iacv, egr valve, starter, maf, coils, radiator if its not leaking, battery, alternator, camshaft pos sensor, fuel injectors just To name a few.
I would think about which parts were replaced in recent years, either by yourself or previous owners. These parts have more life left in them than original parts.
I would also think about all sensors. These are small chunks of concentrated money. You will be able to fix cel codes quickly. Other items that are older, like the alternator, starter, etc can get you car going again when the part on the newer car fails. While these parts cannot be depended on long-term, they can be installed quickly when money is tight.
Those Nissan engineers were busy with the 99 VQ motor experimenting with future emissions stuff for the 2000 model.
So saving those type of parts would be strictly to sell them to another org member with a 99 cali VQ.
dank4us
34
Jun 10, 2024 03:45 AM
FlaMark
25
Aug 28, 2015 10:15 AM
