Rewired Blinkers
Old Jan 16, 2002 | 08:15 AM
max83's Avatar
Rewired Blinkers
ok well I have no turn signal now ,I follwed the instructions from maximadriver.com and cut the black wire(ground i assume)from the side lamp and spliced it into the green(power i assume)frome the turn signal all that did for me was blowing many fuses... I must be missing something cause this is not working....... any advice would be greatly appreciated ....i really need turn signals
thanks
john
Old Jan 16, 2002 | 09:12 AM
benny's Avatar
You must used the black wire conected to the lamp to the green wire.
Old Jan 16, 2002 | 09:17 AM
95emeraldgxe's Avatar
hold on a second........did u follow the instructions for the blinkers or the corner lights?? They are different
Old Jan 16, 2002 | 11:52 AM
max83's Avatar
I used the instructions for the blinkers... and i took the black wire from the smaller lamp and wied it to the green wire from the bigger lamp
Old Jan 16, 2002 | 03:33 PM
Romeo's Avatar
i know what you're talking about. i tried to do it and i blew fuses too. that's kinda weird since on my 95 gxe, i did it the first time and it worked.
Old Jan 16, 2002 | 04:33 PM
maximus75's Avatar
Re: Rewired Blinkers
thanks
john
The black wire that you cut, did you use the end coming from the lamp, or the end coming out of the harness to connect to the green wire?
Old Jan 16, 2002 | 10:10 PM
Romeo's Avatar
i cant remember, i see your point though. that would definately cause it to blow fuses.
Old Jan 16, 2002 | 10:34 PM
krzymax's Avatar
Maxima owner since 2000
get a #10 fuse
Old Jan 17, 2002 | 11:47 AM
max83's Avatar
the black wire is from the lamp and thanks the larger fuse helped but still how do i rewire the blinkers
Old Jan 17, 2002 | 02:53 PM
paul4b's Avatar
Dumb question:
I looked on the maxdriver website, but I cannot find what the blinker mod is for?
Thanks!
Old Jan 18, 2002 | 11:45 AM
paul4b's Avatar
Hey - that's pretty cool.
Thanks!
Sir Tilus
Mar 22, 2016 01:49 PM
Blackwind
Aug 5, 2015 06:35 PM
BippuBenji
Nov 15, 2000 08:00 AM
perlmax90
Nov 13, 2000 06:10 PM
