heater not working, any thoughts?
Old Sep 19, 2013 | 06:05 AM
maxman1988's Avatar
Hey guys, now that it's starting to get cold it again,I need to address this. My heater, it works like a champ as long as I'm driving, but as soon as I park, it just blows cold, any ideas?I live in Colorado so I need this fixed soon cause it gets really cold here really soon, thank you
Old Sep 19, 2013 | 08:34 AM
maxman1988's Avatar
Anybody?
Old Sep 19, 2013 | 02:41 PM
DennisMik's Avatar
Usually when a heater blows cold air when the engine is idling, the The coolant level in the radiator is low. When the engine is cold, take the radiator cap off and check. The radiator should be completely full, no air space.
Old Sep 19, 2013 | 02:42 PM
njmaxseltd's Avatar
Does the engine temperature gauge indicate normal operating temp? Is the coolant level correct If so, then you probably have a clogged heater core. A cooling system flush may be in order.
Old Sep 19, 2013 | 03:05 PM
maxman1988's Avatar
I will check the coolant level when it cools off, and for the gauge, it doesn't work properly, it hasn't since I got the car, it flicks back and forth between all the way down and half way up...
Old Sep 19, 2013 | 03:27 PM
njmaxseltd's Avatar
Temp gauge goes all the way cold and back to normal.... Does this mimick what the heat does?
Check the electrical connector on the ECT sensor, the one furthest away from the block. That's the one for the gauge.
Old Sep 23, 2013 | 09:07 AM
maxman1988's Avatar
Just finally got around to checking the radiator and yes it is low on coolant, I will go to advance auto after work and get more and see if that does the trick
Old Sep 23, 2013 | 10:40 AM
DennisMik's Avatar
Don't forget to put some coolant in the overflow tank and keep checking it for several days when the engine is cold before starting it
Old Sep 23, 2013 | 12:21 PM
maxman1988's Avatar
Okay I will do that, thank you for the info Dennis :-)
dr3am
25
Oct 22, 2015 08:53 PM
homeyclaus
Sep 3, 2015 06:15 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
acw
Aug 7, 2015 04:20 PM
kenc15
Aug 5, 2015 08:29 AM
