sluggish 95 max :(
Old Sep 30, 2013 | 12:15 AM
BocaMax's Avatar
sluggish 95 max :(
Hey guys I havnt posted much thanks to the search button. But my maxima has a sluggish acceleration or at least I feel it sure does. Almost feels restricted, I've tested thet maf and is within specs the crank sensor is within spec I changed the fuel pump with a know good one and no difference fuel filter isn't clogged plugs have about 10000 miles on them I have also swapped out the coils from a perfect running maxima. I found that the rear crank sensor is not reading within the haynes manual specs with the screw driver test. I've read that sensor controls the timing of when to spray the fuel. Is this correct and is this sensor supposed to hwve a liitle nipple sticking out? Will the auto one fit in the manual one? I assume not?
Also not sure if related but the idle hangs around 1500 when I take it out of gear for about 15-20 seconds and then goes down to normal idle and it feels like low power from idle till about 3600ish and then it feels like my maxima "pops vqtec" and starts pulling like i feel like it should.
Old Sep 30, 2013 | 05:10 AM
D I R T Y I 3 0's Avatar
I say knock sensor. Get a cheap one off Ebay
Old Sep 30, 2013 | 05:34 AM
njmaxseltd's Avatar
Check for stored error codes, if the KS come up, change it.
Have you checked the air filter?
Old Sep 30, 2013 | 08:25 AM
BocaMax's Avatar
I've replaced my intake has clean filter I've replaced the knock sensor twice but ill scan my car in a few mins.
Old Sep 30, 2013 | 08:27 AM
Amerikaner83's Avatar
How long has it been since the FUEL filter was changed? I know you say it's not clogged, but when was it last chagned? Also, do you use 87 gas or 92/93?
Yes, check for codes, and if KS pops up, change that again.
You mentioned earlier you had a crank pos sensor code? If you haven't yet, change that sensor if it's not reading within spec.
Old Sep 30, 2013 | 08:28 AM
LTXMitch's Avatar
I'd say KS especially if you have a Auto, just try the easy stuff like cleaning your TB and MAf and check all of your vacuum lines. i did all of this when i replaced my rear valve cover. the KS was a pain to get to because of my '99 EGR setup but it was well worth the bloody knuckles. Good luck
Old Sep 30, 2013 | 08:29 AM
OP has a 95, and a manual. KS should be a breeze.
Old Sep 30, 2013 | 06:39 PM
BocaMax's Avatar
Anyone else any ideas on my issues
Old Sep 30, 2013 | 07:00 PM
bprice92's Avatar
Clean MAF (w/ MAF cleaner) if you haven't already.
Clean IACV.
Clean TB.
Clean EGR.
Tighten up throttle cables.
Old Oct 1, 2013 | 11:03 AM
maxinout93's Avatar
Clean tb, I would also swap out the coil control sensor, change PVC valve, knock sensor, use 89 gas or higher after knock sensor change and u will feel the difference. Adjust your throttle cable. Be sure your oil and tranny fluida are full.
Old Oct 2, 2013 | 05:34 PM
deezo's Avatar
Originally Posted by bprice92
clean maf (w/ maf cleaner) if you haven't already.
Clean iacv.
Clean tb.
Clean egr.
+1
Old Oct 3, 2013 | 08:02 AM
4th gen maxi's Avatar
if you feel nothing but a sluggish start not like a misfire and running an auto its almost certain your one way roller is broken on your torque converter.
not fixable just a replacement will do.
Old Oct 3, 2013 | 08:19 AM
OP has a MANUAL transmission.
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
HOKUSMAX
Nov 13, 2017 04:34 AM
magiconthetire
Oct 26, 2015 09:03 PM
