Cigarette Lighter & Power
Old Oct 4, 2013 | 04:33 PM
webking185's Avatar
this is a silly question, but please bear with me.
plug in my phone charger and it does not work. the fuse is not blown, what do i do next?
i tried different adapters from my navigation, to the iphone and none work.
arggg
Old Oct 4, 2013 | 04:36 PM
Fakie J Farkerton's Avatar
Originally Posted by webking185
this is a silly question, but please bear with me. plug in my phone charger and it does not work. the fuse is not blown, what do i do next? i tried different adapters from my navigation, to the iphone and none work. arggg
Clean or possibly replace the outlet.
Mine had a couple sweet spots where I had to rotate it to get power, but I just went to the junkyard and this one works fine.
Old Oct 4, 2013 | 07:06 PM
DennisMik's Avatar
Probably the outlet is bad as stated. The outlets have a built in fuse in them that can blow. But you could check and see if the wire going to the outlet has 12 volts before buying anything, just in case.
Old Oct 5, 2013 | 02:57 AM
1996blackmax's Avatar
That's exactly what I had to do with mine. I ended up cleaning it very well & it worked fine after that.
Old Oct 5, 2013 | 08:39 PM
jfactor's Avatar
Probably just best to replace it, I'm going to be doing that here soon since mine seems to be getting a little iffy.
Old Oct 9, 2013 | 06:34 AM
webking185's Avatar
just went through the sticky notes and didn't find any posting on removing it, can someone walk me through this, thanks.
Old Oct 9, 2013 | 07:03 AM
njmaxseltd's Avatar
Poop the trim off around the gear shift. It's just held on with clips. Remove the power socket, clean or replace.
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
leatherneck
Sep 30, 2015 09:16 PM
