it won't start
Old Oct 5, 2013 | 04:32 PM
EnriqueA32's Avatar
my maxima won't start please help
I have a 1996 nissan maxima. It used to be automatic but I converted it to a five speed. The car ran perfectly fine for two years when it slowly started with a starting problem. It first took a few seconds to start then it started taking minutes about ten to fifteen minutes to just start. At the same time it start getting a sort of power loss and lag if I tried running it fast otherwise it drive just fine. Then one morning it justnever started again and I haven't been able to find the problem. I'm thinking of buying a donor car but before I drop that kind of money I wanted to see what I could do to fix this one. One more thing the my third gear went out about a year after the swap and I never got around to fixing it.
Old Oct 5, 2013 | 05:30 PM
chrome91's Avatar
first thing i would personally check is fuel pressure, fuel pump may have been slowly dying out. if fuel pressure is okay, check for spark
also scan for codes
Old Oct 12, 2013 | 03:30 PM
EnriqueA32's Avatar
also scan for codes
The fuel pump does come on so its not that pressure off the filter i haven't checked and codea I need to get a scanner for that
Old Oct 12, 2013 | 06:42 PM
Slamrod's Avatar
I think your very first course of action would be to scan for codes. Im sure someone could list of possibilities but if you could pull up a code that would be eons faster than guessing.
Old Oct 12, 2013 | 09:56 PM
DennisMik's Avatar
Just about all auto parts stores will scan your car for codes for free. Next time you drive by one, stop in.
Old Oct 12, 2013 | 10:01 PM
asand1's Avatar
Did you sand the mating surfaces of the engine and transmission? Voltage drop from poor ground will wreak javoc on the sensors.
Old Oct 12, 2013 | 10:06 PM
asand1's Avatar
Check codes with the screwdriver method.
Old Oct 12, 2013 | 11:23 PM
Slamrod's Avatar
Might not be the easiest method of scanning considering his car doesnt start haha.
+1 on screwdriver method, may be tedious but sure beats buying/renting a scanner. Just make sure youre gentle!
Old Oct 13, 2013 | 12:56 PM
DennisMik's Avatar
Oops... minor detail.
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
markevans999
Sep 10, 2015 04:29 PM
trungg86
Sep 4, 2015 04:58 AM
