Click under dash
Old Oct 5, 2013 | 05:04 PM
Ridamaxout's Avatar
Click under dash
Ok ive changed a starter & ran a new starter wire but I can turn the engine over by jumping the cylinoid but it will not start &,when I use my key it makes a click on the far left side of the dash. Any ideas?
Old Oct 5, 2013 | 05:37 PM
DennisMik's Avatar
There are several relays under the dash on the left side that make a click, but you usually don't hear them because the sound of the engine cranking drowns them out. If the clicking is fairly soft, then this sounds normal.
Two sort of common things that happen are the ignition switch being bad or the park/neutral switch on the transmission is bad.
Assuming you have an automatic trans, try wiggling the shift lever when turning the key or put the lever in neutral and try starting the car. If this doesn't work then take the ignition switch off and turn it with a screwdriver.
let us know how this works for you.
jmlee44
Oct 2, 2022 02:13 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
