auto ranny slipped from 2-3. how long do I have?
Old Jan 16, 2002 | 06:41 PM
vinny1978's Avatar
a little slippage. how long to guys think the tranny will last?
Old Jan 16, 2002 | 06:46 PM
95emeraldgxe's Avatar
hrmm - you should have someone take a look at it while your car is still running......
Old Jan 16, 2002 | 06:56 PM
vinny1978's Avatar
should I get the vb mod.
Old Jan 16, 2002 | 06:57 PM
max808's Avatar
Re: auto ranny slipped from 2-3. how long do I have?
Check the ATF and see if it needs to be flushed. Look for brown color or burnt smell, also feel if it's slippery.
Old Jan 16, 2002 | 07:08 PM
vinny1978's Avatar
didn't even think of it. i don't think it has changed in a while. probably needs to be flushed
Old Jan 16, 2002 | 07:13 PM
Yellowbrother's Avatar
accelerate really slow...
Old Jan 16, 2002 | 07:53 PM
Greddy97's Avatar
mine does that too. i have 72000 miles on the car. when it does this, does it mean im gonna have to get a new tranny. I just got the fluid changed n stuff but it still does it/.
Old Jan 16, 2002 | 07:56 PM
Maxilicious's Avatar
I look forward to my tranny blowing so I can convert to 5sp. I see it as an opportunity.
Old Jan 16, 2002 | 08:15 PM
Greddy97's Avatar
Start Doin Neutral Drops on a regular basis
Old Jan 16, 2002 | 09:37 PM
skimax's Avatar
vb won't help, just drive it easy and you should be ok. when my car started to slip, i still pushed the car which led to no reverse
and no first gear. but i was able to get reverse and first gear once in awhile then total loss. so just drive it easy and you should be good.
Old Jan 16, 2002 | 09:51 PM
for sHo's Avatar
Originally posted by skimax
just drive it easy
Now THAT is asking for a litttttle TOO much my friend...
Old Jan 17, 2002 | 09:32 AM
vitas's Avatar
not long enough
Old Jan 17, 2002 | 09:37 AM
hlh0501's Avatar
oh dang,
I lost reverse ummm 6-9 months before my tranny went.. and I still drove it QUITE HARD once I had lost reverse. Reverse would slip super bad, and then it all out went out. From then, 1-2 slipped real bad, and i kept driving it - hard
I didnt care... once that shift got bad, it wouldn't take off from the line, it would run to about 5000rpm and then engage, resulting in super tight burnouts!!! was one of the coolest things ever, didnt have to worry about tranny damage from burning out, and 5000rpm drop in an auto was amazing haha.. I only drove it like that for a day cause it was a pain, I couldnt take off from a redlight without burning them super bad.. it was awesome though showing off hahahha
If you drive it easy, you should have alittle more life out of her - can't give a definate time, but 2-4 mo ?
Old Jan 17, 2002 | 11:28 AM
jdmmax's Avatar
so how do i know if my tranny is slipping.
is it cause its sifting late or when you gas it the car dosen't pull.
Old Jan 17, 2002 | 11:45 AM
hlh0501's Avatar
just like a slipping clutch on a 5spd, the engine wil rev, but the car will not pull... shifts will get reeeall delayed and drawn up (high revs) until it gets into the new gear..
Old Jan 17, 2002 | 01:05 PM
jdmmax's Avatar
ok i guess i am safe for now. the only reason is that recently i can feel that my tranny is not what it use to be. i don't know if it is just me or if the tranny is begining to go out.
Old Jan 17, 2002 | 05:00 PM
brubenstein's Avatar
If the ATF gets too hot it forms gums and varnish that get deposited in the passages and shift selenoids. This will cause the shifts to take longer and cause more slipping of the clutches, more heat, etc. Places that use a flushing agent (solvents) in their fluid exchange machines will get this crud out. You can also do it yourself by adding a few oz's of Marvel Mystery Oil to the trans and then drive it for a few days. Then get a full fluid exchange. On a trans with your milage, I would suggest Valvoline Maxlife ATF. I would also add a botttle of Lubegard (red) (see: http://www.lubegard.com/automotive/atp.html)
Old Jan 17, 2002 | 08:55 PM
vinny1978's Avatar
LubeGuard after I get it flushed?
AaronL
Aug 8, 2020 10:31 AM
Maximeltman
Sep 28, 2015 07:19 PM
dshinn
Sep 26, 2015 08:07 PM
homewrecker
Sep 24, 2015 07:01 PM
