ECU code - 0303
Old Oct 23, 2013 | 05:15 PM
badfish74's Avatar
ECU code - 0303
I'm getting a 0303 code from the ECU on my 96 max (auto). I know it's a o2 sensor and the decoder says "Left Front heated o2 sensor". Trying to search, I only come up with bank 1 & 2. Can someone tell me what bank is left or right. I guess the easiest way to determine this would be radiator or firewall.
Sorry if this has been asked a million times. I did try searching but couldn't find a direct answer.
TIA.
Old Oct 23, 2013 | 05:52 PM
2brosgixxer's Avatar
http://forums.maxima.org/6432120-post1.html
Old Oct 23, 2013 | 06:45 PM
badfish74's Avatar
Thanks! That clears things up.
Old Oct 24, 2013 | 11:07 AM
DennisMik's Avatar
Front wheel drive cars confuse the definitions of left and right because the engine is mounted sideways. Then there are the multiple terms for the same thing.
Left side = bank 2 = firewall side.
Right side = bank 1 = radiator side.
Front sensor = sensor 1 = S1 = upstream sensor = sensor mounted in the exhaust manifold.
Rear sensor = sensor 2 = S2 = downstream sensor = sensor mounted in the exhaust y-pipe after the manifold (Cali spec) or after the main cat (Fed spec).
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
