12v car power adapter
Old Oct 26, 2013 | 02:27 PM
Boule's Avatar
How would I go about fixing cigarette lighter?
When I bought the car it never worked. Months ago I took out the adapter. I put a new fuse in it and still no go. Could someone link me to a car power adapter that would fit my 98 max, preferably ebay but amazon will do too.
Old Oct 26, 2013 | 03:52 PM
tigersharkdude's Avatar
If your lighter socket isn't working then an adapter that plugs in to it isn't going to work
Have you taken the shifter trim out to see if the socket is even plugged up?
Old Oct 26, 2013 | 04:55 PM
Boule's Avatar
I didnt do that but the wire that it was plugged into, I have access to that...
Old Oct 26, 2013 | 05:27 PM
The only wire that plugs into that socket attaches behind the shifter trim.
You need to figure out why its not working before using an adapter. be cause if the harness doesn't have power then an adapter hooked up isn't going to work
Old Oct 26, 2013 | 07:34 PM
DennisMik's Avatar
The cigarette lighters have a built in fuse that can blow, meaning you have to replace the socket. So if you have 12 volts on the wire, the socket is bad.
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
JRod28
Feb 4, 2016 11:07 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
mikekay
Aug 10, 2015 12:52 PM
