Questions on Cylinder Head Gasket Repacement
Old Dec 8, 2013 | 07:38 AM
fixandfly's Avatar
Hello:
I would first of all thank everyone for the helpfulness and input
and Maximeltman started with some answers.
95 Maxima 3.0 Engine
Failed the radiator Block tester with the carbon dioxide reactive dye
#1 Why does the upper and lower oil pans have to be removed when taking off the Front/Rear timing covers?
(are there bolts that come up from the bottom?)
#2 If I don't own a sling to support the engine from the air
and all three motor mounts are removed what and where can I support from the ground?
#3 Can only the lower pan be removed without the big upper pan removed?
#4 Can the heads be removed with only the front timing cover removed? Or must the rear timing cover also be removed?
Fixandfly
Old Dec 8, 2013 | 03:56 PM
gruesome's Avatar
just the lower oil pan to take off the right side timing cover. There are a couple bolts hidden. There are a couple timing cover bolts that are a bear to get at. If you don't use the screwdriver in the factory Jack kit, weld a 10mm socket to it. it's impossible to get a wrench or ratchet in there with the engine in the car.
Old Dec 8, 2013 | 04:54 PM
fixandfly's Avatar
Did you mean Front or back timing cover?
Old Dec 8, 2013 | 05:42 PM
gruesome's Avatar
The one with the water pump
rnb754
Sep 14, 2015 11:39 PM
aminus21
Sep 12, 2015 04:53 PM
bbsitum
Sep 11, 2015 04:55 PM
videomano
Sep 8, 2015 03:28 PM
Johnny9595
Sep 3, 2015 05:18 AM
