Car dies out plz help
I have a 98 maxima and as I was driven the break and battery and air bag light turned on and when I tried to accelerate it did not respond and wanted to turn off then I tried again and it worked this time but then a little down the road it died out. When I jumped the car it turned on then drove a little and turned off again then again and did the same. A day went by and I jumped it again it started fin then as soon as I turned on the lights it died. It has a new battery starter is new placed it 4 months ago and alternator is good. Plz help
I know you say the alt.is good, but it sounds to me its on its way out! especially if its a reman alt. many people have bought reman alts. and they either were bad out of the box or died soon after installation...4th gens do exactly what your car did when the alts are crapping out! air bag light etc.
Posted from Maxima.org App for Android
I had the same issue on my '01 Max and I jumped it when it died thinking I could at least drive it the 2.0 mile trip home.. but boy was I wrong. Had to jump it 4 more times and coasted into my driveway as it died again. Of course it decided to do this on a first date.-__- but my "smoothness" and "charm" got me another date
with the car idling, put a voltmeter across battery positive and negative. tell us what you get
lights wonking out, needing a boost, etc are all bad alternator symptoms. my 3rd gen did the exact same thing when the alternator went. you cant assume the alt is good, ive seen reman alternators fail 2 months after being installed
agreed!...i forgot to mention the harness....now i know a 4th gen isnt a 78 ford pinto, but that was my 1st car back in the day and the harness crapped out on it...after 2 alternator installs i found out it was the harness!
Definately check the charging system but outside of the altenator issue could also just be a bad connection. I had a buick that did that exact same thing as you described with all the same symptoms of a bad altenator but just wound up being a bad positive connection to the battery.
Lakersallday24
06-16-2019 01:35 AM
kjlouis
11-24-2018 06:09 AM
Maxboy23
08-11-2015 11:59 AM
