Z32 Brake upgrade brackets
Old Feb 25, 2014 | 07:44 PM
  #41
CMax03's Avatar
Do you have a p/n for this 30mm Z32 caliper or what year it's found on?
Old Feb 27, 2014 | 01:41 PM
  #42
Cebby's Avatar
The fastbrakes brackets are beef (even if they are aluminum). I've run them for at least 20k trouble-free miles so far. No extra washers or grinding calipers to make them fit either - they are milled from a single chunk of aluminum, so no welds to fail like on the steel ones.
http://www.fastbrakes.com/product_p/...2%20brembo.htm
Old Feb 27, 2014 | 05:07 PM
  #43
ShocknAwe's Avatar
just search for a 1996. You can use the 30mm aluminum or iron. Just not the 26mm. Fast brakes is a decent enough kit but Ill stick with the steel. A better bracket. The stock caliper set-up uses washers. Every kit does. Its to get it centered perfectly. This is just another option for people. If modification scares you then stick with aluminum
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
