P1335 code help please
Old Dec 28, 2013 | 11:21 AM
Patm-a32's Avatar
Hey guys, changed my oil yesterday, after finishing i put the key in the ignition and went to start the car as usual, the car is turning over but it is cranking a lot faster then usual and cranking for about 5 seconds before it fires up. The car through a p1335 CEL code. Today went out cleaned the wiring harness to the crank position sensor and replaced the sensor it self. Car still not starting right and still gives me the p1335 code every time I fire up my car even if I clear the code. Battery is brand new, sensor and harness are good, and starter is about a year and a half old. The car runs fine when started and ran fine before I changed the oil. I'm stuck any help would be appriciated
Old Dec 28, 2013 | 01:33 PM
DennisMik's Avatar
The p1335 code refers to the sensor CKPS (REF) that is mounted on the oil pan by the oil filter. It is used to determine top dead center for spark timing. If this sensor is bad, the engine will still start, but it will crank longer before starting.
Is this the sensor you replaced?
The other sensor, CKPS (POS) is checks the flywheel. If that sensor is bad, you get a P0335 code and the car won't start.
Old Dec 28, 2013 | 04:38 PM
Patm-a32's Avatar
Actually no the one i replaced was the crank shaft position sensor that is right under the crank shaft itself.... Not sure if were talking about the same sensor but the battery is also new and i just replaced the starter this morning. the car does start just takes a few seconds of cranking. Runs and drives normal once it gets fired up but the engine light p1335 stays on. Again this happend right after i changed my oil. Before the oil change car started and ran as normal as always with no CEL
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
