Light tapping noise coming from engine
almost every time i start my 98 maxima, there is a light tapping noise that sounds like its coming from the top of the motor, like around the rear valve cover. what should i do, should i be concerned???
Apparently this is extremely common, considering it is probably just the injectors... injecting.
But in all seriousness many people have this complaint - the injectors for our car are pretty loud.
Is this a new issue? Also if you can get a sound clip that might help in allowing you to rest assured.
it does it lightly at idle but mostly and is the loudest on a cold start. and this started a few weeks ago. hmmm i wish i could get a better video..... sounds more like valves... and also, it was a little low on oil but i put another quart in it but it still does it all the same
My car makes the same noises your describing. Louder on a cold start. Its a constant ticking that doesnt really get louder but it ticks faster as the rpms go up. Oil level doesnt make a difference on mine sounds the same all the time. Sounds like valves or lifters.
Possibly a sticky lifter or valve train. what kind of fuel are you using? Try using some premium with a higher octane for a while and see what happens and like previously suggested it just aswell could be a noisy timing tensioner with bad bearings aswell. Have you put a stethescope on it to try to pinpoint where the noise is travelling from? Another thing you could do is do a flush on your next oil change to help clean out any contaminants and use a thicker viscosity oil to dampen the noise and quiet it down a little but i'd still work on diagnosing the source. Maybe the previous owner didn't keep on top of their regular oil changes but again i wouldnt rule out the tensioner so get out your stethescope. asand1 was not only recomending you to top up your oil the important part he was trying to get across to you was try changing your filter possibly due to a cheap anti drain back valve. Doesn't hurt either seeing a good filter is only $10. Might not hurt to try if you decide to do a flush and use a thicker viscosity oil.
Damn, are you a mechanic... lol. But that is all a great idea. I usually run 89 octane or sometimes 87 octane with NOS Octane Booster. In the next couple of weeks im going to be changing the Valve Cover Gaskets, Intake Manifold Gaskets; Changing the Oil/Oil Filter with Castrol GTX High Mileage/Bosch Oil Filter, and replacing the Spark Plugs with Bosch Platinum Fusion IR4 Spark Plugs and I was also thinking about putting some Lucas Oil in when I change the Valve Cover Gaskets and the Oil.
But.... that wont help the OP.
Edit: oops you are the OP.
JMag90
08-25-2015 09:17 AM
MaximaDrvr
08-19-2015 08:20 PM
kirkhilles
08-08-2015 10:53 AM
