What do these Engine Malfunction error codes mean?
My '98 has been sitting for a couple of years and after making some repairs and driving it around for a couple of days, the Engine Malfunction light lit up. I copied the three number sets down several times to verify that I was not making any mistakes, then turned the key back a repeated the whole procedure, but two of them do not seem to correspond to anything, according to this page: http://vbxmaxima.8m.com/ecudecoder.html.
28 41 49
I plugged the intake sensor back in and I reset the light, so at least the 41 error code should be taken care of when I turn it on tomorrow. What do the 28 and 49 mean?
28 41 49
0208 engine overheat, abnormal high temp
0401 Intake air temp sensor
0409 right bank oxygen sensor
http://www.boredmder.com/ecucodes/in...Y1998&DTC=0208
75 = 0705 = P0440
Evaporative Emission (EVAP) Control System (Small Leak) (Negative Pressure)
Note: If both P0440 and P1448 are displayed, perform TROUBLE DIAGNOSIS FOR DTC P1448 first.
39 = 0309 = P1448
Evaporative Emission (EVAP) Canister Vent Control Valve (Open)
Go here and download the EC section of the service manual.
http://www.nicoclub.com/FSM/Maxima/1998/EC.pdf
Code 0705 (P0440) is on page 274 and code 0309 (P1448) is on page 396.
39 = 0309 = P1448
