Stalling when idling issues
Good Morning All,
I am needing some help. I have a 1995 Nissan Maxima GLE that has about 240,000 miles on it. Lately I have been experiencing some stalling when idiling as if the car wants to cut off. This morning when I crunk up the car to let it warm I smelled gas fumes. As I was driving into work my acceleration was smooth, but then it started to kind of slug.
I have replaced my starter, battery, and battery post. Put in new fuel filter and I even did the spark plug check. The thing that is so weird to me is that my CHECK ENGINE SOON light is not even on.
Any suggestions as to what might be causing this and what I need to do?
The car runs quiet and smooth and I have not had any problems with LilleMae until now.
Help Please!!!!
Help Please!!!!
Good Morning All,
Help Please!!!!
Help Please!!!!
Does the CEL come on for a second before cranking the engine over? The light could be burnt out. In cold weather the fuel will often leak through very fine cracks in the fuel lines at the fuel filter or between the fuel rails.
If its sluggish it might be time for plugs, air filter and TB, MAF and EGR cleaning.
I had my radiator go empty on me one day in my 95 and it didn't cause any issues like these. Then again I was driving on the highway with the heater full blast to keep the temp gauge close to normal as I could.
Well, it was driving like that for awhile. Days, maybe weeks? I never thought to check the radiator until noticing the temperature gauge. And perhaps something else was contributing to the loss of power. Since posting this, I've replaced my radiator and discovered my engine to be out of oil. Perhaps there's a connection between the two.
I had a simular problem a while back. Check the maf sensor first as it controls the fuel air mixture. But mine didnt have the fumes. Mine stalled at idle and the idle air control valve caused it. It has two solenoids, one is for the a/c and the other is for power steering. When you turn he steering wheel to one extreme or the other the engine should idle up a little higher. It should also idle up a little higher when you turn the a/c on. Thats the quick check.
mine was stalling like your saying and it was the MAF...I bought a new one on ebay for 33 bucks. I was wondering about quality but it works perfect. no more stalling and has quite a bit more power. I also sprayed the throttle body with cleaner and added a new air filter. Its a 95 SE auto and will spin the tires on takeoff now.
stahlling and fumes
Ya she wasnt too happy I got it the same week. Too Bad.
97_GXE
20
Sep 17, 2015 08:12 PM
97_GXE
Sep 15, 2015 06:47 AM
