95 ECU swapped into 99...having issues
hi i have 1999 nissian i am no getting injector pulse i swap in a 1995 ecu and wire it up i test the crank ref sensor and i get 0 volts ac when i crank the engine i put a new crank ref sensor in and still the same thing
Thread title changed to something with meaning.
Did you follow this?
http://forums.maxima.org/4th-generat...p-success.html
And please don't create multiple threads on the same subject. Post all your related q's and problems in this thread. Thanks.
I've never done the swap, but the whole point of the swap is to getting away from the dreaded NATS system and the programming of keys. So that should answer the first part of your question.
EDIT: As for the ECCS relay, that's by the driver's headlight.
I don't think there is a fuse specifically for the injectors. Just a fuse for the fuel pump that I know of (by your left knee when sitting in the car).
pktaske
05-06-2016 07:49 AM
JoshG
09-05-2015 10:10 PM
pktaske
09-04-2015 08:40 AM
