So How Complicated Is This? ... Trans Filter Replacement
Old Jan 22, 2014 | 12:16 PM
Turbobink's Avatar
I've tried to do a bunch of searching and a bit of reading and even went to the FSM.
However, I have, up to now been unsuccessful in locating the procedure for the removal and replacement of our transmission filter.
In shopping for the piece I ran across an advisory stating, "replacement of filter requires valve body removal."
So, instead of searching the FSM for the written procedure, I thought I'd have a look at the exploded graphics ... sure as sh*t.
So ... how complicated is getting to and pulling this thing so's a new one can go in?
Old Jan 22, 2014 | 12:34 PM
Amerikaner83's Avatar
there is not a "filter" per se...it's a screen, and is not intended for replacement.
Old Jan 22, 2014 | 12:41 PM
SupaMaxima's Avatar
There is no need to replace it. It's a screen as Ameri said. When I took mine out, I just cleaned it. There were some small metal shavings that I removed with some tweezers and place it back. Valve body removal is not required. When you removal the trans. pan you will see the screen held by a screw or two.
Old Jan 22, 2014 | 12:46 PM
NmexMAX's Avatar
dot dot dot ...
Very easy.
Old Jan 22, 2014 | 04:27 PM
Turbobink's Avatar
So apparently that graphic, which is right out of the FSM, shows the valve body/screen assembly inverted?
Old Jan 22, 2014 | 05:17 PM
jholley's Avatar
That graphic is upside down. The permanent metal screen is bolted onto the bottom side of the VB.
For guidance on dropping the pan and screen read post 399 of this thread
http://forums.maxima.org/fluids-lubr...-level-10.html
Old Jan 23, 2014 | 05:50 PM
1992maximase30's Avatar
some had to remove the valve body because the screw in the middle sometimes had to be held on the other end. another thing to note you should clean out the little screens on the shift and t/c solenoids. this actually caused drivability problems for my dads car where he thought the trans was gone. but we...well i replaced the shift solenoid kit and filter and shes still rolling at 200k
Old Jan 25, 2014 | 12:54 PM
Trini Boom's Avatar
This is correct but on my 95 didn't have a problem removing the middle screw. Wish I knew about the small screens on the shift solenoids...
Old Jan 25, 2014 | 01:16 PM
Turbobink's Avatar
Much obliged for the insight men ...
Old Jan 29, 2014 | 07:22 AM
This is one of the main reasons why the trannies go out.
vingodine
45
May 21, 2016 12:46 PM
Starrider
Sep 17, 2015 07:26 AM
homeyclaus
Sep 3, 2015 06:15 PM
Balkins
Aug 12, 2015 06:39 AM
kirkhilles
Aug 8, 2015 10:53 AM
