How to switch to heater manually
Old Jan 25, 2014 | 10:10 AM
Nonameslim's Avatar
95 Maxima
My heater/AC controls do not work. i wont have the money to replace the controls for another 2 weeks but with the current freezing in Houston, I need the heater to work for my wife and I. Is there a way i can go behind the dash and manually turn a switch or lever to switch from the ac to heater?? ANy help is appreciated!
THanks!!
Old Jan 25, 2014 | 10:50 AM
njmaxseltd's Avatar
Auto or manual climate control?
What part of the control isn't working?
Old Jan 25, 2014 | 11:43 AM
Nonameslim's Avatar
It is auto and the temp adjuster is not working. the display will show 85 but still blows cold air. all coolant is up to par also so my best guess is the adjuster panel thingy is not working.
the fan speed works, mode works, everything except the temp adjust.
Old Jan 25, 2014 | 02:37 PM
asand1's Avatar
Blend door motor is not working. You should ne able to disconnect the linkage and move the lever by hand.
Old Jan 26, 2014 | 06:12 AM
DennisMik's Avatar
Asand1 has the right idea. When you disconnect the linkage to move the door manually, you will have to figure out how to hold the lever in the heat position because it moves fairly easy.
tarun900
19
Dec 20, 2021 06:57 PM
gavin68
Sep 18, 2021 12:36 PM
howardis
Dec 11, 2019 06:10 PM
leatherneck
Sep 30, 2015 09:16 PM
