Please help!!starting issue
Old Feb 8, 2014 | 12:19 PM
carlitosv214's Avatar
so i have a 97 maxima that i had for a while. she always had this starting issue where it turned and turned and would start after 8 turns. recently it broke dow(starter went bad)n because of the starting issue and ive been working on it. Ive done everything ive possibly could have thought of. I changed the starter, cleaned all grounds except trans and engine surface, checked all fuses and relays, changed the fuel pump 3 times, ran a fuel pressure test and its giving me 45 psi, changed all three sensors with new ones(crank near pully, crank near transmission, and cam sensor), combustion test and all gave great readings, theres a spark. i even did the timing chain kit on it because a couple of tensioners were worn out. When i go to try to start the car it turns and turns and at times it gives a back fire. something like this....ra ra ra ra ra dunkk ra ra dunk dunk. im clueless what i could try next. any suggestions? also is there a way to check if my ignition switch is working correct? please help with any ideas. its my only form of transportation and i need it to work. thank you
**** when the car starts which is rare, the car runs great and perfect.***
Old Feb 8, 2014 | 03:30 PM
njmaxseltd's Avatar
You have a thread already started for this issue which has suggestions and help for you.
Please continue with that thread.
Moderators close please.
Old Feb 8, 2014 | 06:24 PM
^Yup. Please use your other thread carlitosv214...
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
trungg86
Sep 4, 2015 04:58 AM
