not happy with wiper LED install
after i installed the nozzles i was so happy looked good andn they were easy to install........but as i started driving to work water was comming out of the nozzles by itself....WTF is up with that??? i installed them right i do not understnad how water cna be leaking out...
That is very strange because the nozzle has nothing to do with water coming out when the water squirter pump is not operating. Make sure the motor is not pumping. You can try disconnecting the motor and see if the water still comes out. There might be a one way valve also that may be malfunctioning.
The whole washer assembly is very simple. Shouldn't be too hard to troubleshoot.
Originally posted by 95emeraldgxe
are u serious?? - it sounds real strange.......does the water come out full blast or does it just drip?
Tai Mai Shu- everyhtign is fine...i know that the water shoudl only come out when the lever inside the car is activated....when i pulled out the hose fromt he stock nozzles no watter dripped out of the hose...so i know that stuff is working fine...thanx guys! and more solutions please respond to the thread thanx!, Tom
try gettin all the air out.....take all the windsheild washer fluid out and then replace it again??
Originally posted by hockeyghst
yeah it is strange....it does not come out with pressure just comes out and leaves a puddle around the nozzle....i donno
Originally posted by SuDZ
When you run the washer fluid do you hear any other odd noises coming from anywhere?
SuDZ
SuDZ
nope........the water leaks on my hood at any given time...when im driving-when its parked.....anytime....and there aare no strange noises.....
Originally posted by BenBlanco218
I dunno, but I reomved my washer nozzles after awhile because the chrome reflector inside began to rust. This happened on 2 pairs of mine.
your car looks very nice. love the intelliglow needles with the reverse indiglo.
MaxLife17
06-27-2019 01:37 PM
jds22
09-04-2015 01:52 PM
