99 EGR Delete Questions
Old Mar 4, 2014 | 01:06 AM
MaxiMike's Avatar
I'm working on my 00VI n in order to delete the egr I just need to bypass the throttle body coolant lines n the ones on back of the intake manifold, right? Also need a block off plate for the egr tube n rear header plug, right? Do I missing something?
Does it exist some way to the cel light doesn't turn on with this mod?
Pros and cons?
Old Mar 4, 2014 | 09:38 AM
Quickywd01's Avatar
EGR exhaust gas recirculation helps during cruising to give you better gas mileage etc. There is a factory egr block off tube that came on some '00-'01 Variable Intakes. I found one for myself but then I bought used cattman headers with a egr tube so I'm using egr. But for you, you can block it if you'd like and leave the sensor plugged in and it'll work fine with no cel. Heres a pic of factory egr block off http://forums.maxima.org/8458195-post67.html EGR clogs over time so nobody likes it.
Old Mar 7, 2014 | 09:16 PM
MaxiMike's Avatar
Well i also removed my 00vi from a 01 so i have the uim bop n the header tube plug, i also made a bop for the egr tube n there is where I'm gonna install the sensor. Now since I'm gonna use the 4th gen iacv as well i put a bop to the 5th gen throttle body, here is my question what u did with the coolant hoses? Did u bridge em or u just plugged em up? Can u text me i may have another questions n i think it will be easy that way if u don't mind (915) 820-5626 Thanks
Old Mar 10, 2014 | 08:35 PM
Quickywd01's Avatar
I think you can just not run coolant into the throttle body. You can put a piece of hose from one end to the other nipple. I think that's for cold climates so the throttle plate doesn't freeze. Just make sure before you do it, do a quick search to see if the ecu checks for that temperature so that the iacv doesn't stay in choke mode. Been a while and I forgot.
Old Mar 13, 2014 | 12:57 AM
MaxiMike's Avatar
Aight thanks man!!
Old Mar 14, 2014 | 06:14 AM
Quickywd01's Avatar
You are welcome.
shilov
Feb 19, 2024 09:40 PM
Unclejunebug
Apr 2, 2016 05:42 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
bumpypickle
Sep 20, 2015 08:22 AM
bumpypickle
Sep 19, 2015 01:07 AM
