Spark plug help
Old Mar 5, 2014 | 09:15 AM
Patm-a32's Avatar
Spark plug help
Hey guys can someone give me a walk through of changing the rear plugs on my 99 max... The fronts are cake i just dont know how to go about doing the rear plugs.. Im doing the ngk double platinum, and my plugs in my car now are original with 150,000 miles so they need to be changed... Can someone walk me through doing the rears, and mabey the tools i need
Old Mar 5, 2014 | 09:26 AM
4th gen maxi's Avatar
You still get spoon Fed?
There's this magical tool we call the search function. It works flawlessly and its free
Old Mar 5, 2014 | 09:50 AM
Fakie J Farkerton's Avatar
Originally Posted by 4th gen maxi
You still get spoon Fed? There's this magical tool we call the search function. It works flawlessly and its free
This topic has been covered MANY times
Heck, there is probably a YouTube video on it.
Old Mar 5, 2014 | 10:26 AM
njmaxseltd's Avatar
It's the same as the fronts, make sure you have a longer extension. There may be one or two components in the way, remove/move them.
Old Mar 6, 2014 | 07:03 PM
nissan99's Avatar
check you-tube there are plenty
Old Mar 6, 2014 | 07:15 PM
sanford7575's Avatar
Dude, it's the same procedure as the fronts, you just need an extension on the ratchet and socket, and you need to remove that brown thing that blocks the spark plug hole furthest to the left. I think that I used Denso plugs though...
Old Mar 6, 2014 | 07:42 PM
Quickywd01's Avatar
Go by the fender of the car by the wheel and bend over, stick your hood under the hood and look in there you can see it's easy. Two screws holding each coil down. The older the car the harder it is with respect to stuck rubber coil boots and other problems.
Old Mar 7, 2014 | 08:45 AM
Patm-a32's Avatar
Just took a look under the hood found where all six are located seems easy enough, just wanted to make sure this job wasnt going to be a ***** to do... Am i better off with the double platinum plugs from NGK? Or is there a better plug that NGK sells
Old Mar 7, 2014 | 09:00 AM
NmexMAX's Avatar
dot dot dot ...
Stick with NGK's. I use Cu's have for a nearly a decade and a hlaf. Less time interval but it's easy enough.
Old Mar 10, 2014 | 12:38 PM
Quickywd01's Avatar
magiconthetire
Oct 26, 2015 09:03 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
