PR CAI problem/question
Old Jan 19, 2002 | 09:43 PM
maximaIL's Avatar
Installed the PR CAI today and took the max for a test drive. wow its insane, and a damn beautiful sound. the only problem is that when I make right turns, i hear a scraping/rubbing noise maxil ...sounds sorta like the noise you hear when you drag a metal shovel over concrete. has anyone had this problem or know what i can do to fix it? thanks all, this mod kicks a**.
Old Jan 19, 2002 | 09:59 PM
SpeedFrk38's Avatar
Re: PR CAI problem/question
probably the intake pipe rubbing on your newly drilled hole. use some type of filling material to prevent contact between the hole and the pipe (ie. rubber).
that should help.
Old Jan 19, 2002 | 10:14 PM
maximaIL's Avatar
Re: Re: PR CAI problem/question
that should help.
Thanks, I'll check on that. But the kit comes with a lining that snugs around the pipe. And if that were the prob, then wouldn't it make that noise all the time, not just when i make right turns? Thanks again for your advice
Old Jan 19, 2002 | 11:24 PM
95emeraldgxe's Avatar
u hear rubbing?? - yeah - he is probably right....try to fill in the hole
Old Jan 19, 2002 | 11:31 PM
Ravq's Avatar
If the noise is that noticeable then you've got to be scratching/rubbing something. Look around for signs of damage like scratches on the tubing and you'll probably find the culprit in no time.
Old Jan 20, 2002 | 09:19 AM
maximaIL's Avatar
thanks for posting
I have some silicone caulk and I'll search the pipe for damage as suggested. thanks again for the help. i'll post again if i cant find any scraping on the pipe.
maximail
Old Jan 20, 2002 | 08:02 PM
i have the Place racing intake...till this day i havent had a problem.. u might wanna check to see if the k&n fliter is not touchin the splash ...n by u turnin its pushin the piping... u should have at least a few inches clearance between that wall n the filter.......but that cold air shouldnt move .... once in place...it as stiff as a *&%^ well let us know how u doin .
Maxima_Joe
Nov 25, 2015 08:19 AM
Sep 27, 2015 08:37 AM
A32goldylocks
Sep 16, 2015 01:33 PM
lowpost99
22
Sep 2, 2015 04:38 PM
BGTONIO1991
Aug 11, 2015 07:38 AM
