Front headlights.
Old Mar 10, 2014 | 03:43 PM
maxim14212's Avatar
Front headlights.
Wanted to ask the experienced forum members a question relating to front headlight. My car was in a fender bender from front and I changed the old headlights with aftermarket headlights from ebay. These lights worked fine for the first day but the next day they weren't working so I played around under the hood with the wires that go to the bulbs in the headlight assembly. When I move the connectors they seem to work but after I let them settle they stop working. So I was wondering if I could solder the wires together instead of the connections. Would really appreciate the help from the generous folks of the forum.
Old Mar 10, 2014 | 03:51 PM
maxfever1987's Avatar
Do you have the one piece headlights and if so are you using the harness supplied with them?
Old Mar 10, 2014 | 04:27 PM
jholley's Avatar
If you inserted the R34s aftermarket headlights made in Taiwan then you'll need to ziptie the connectors together. They don't snap on snug.
Old Mar 10, 2014 | 08:00 PM
maxim14212's Avatar
reply
Yes did try them but still not effective.
Old Mar 10, 2014 | 08:58 PM
Quickywd01's Avatar
Solder them instead, perhaps the pins in the connectors are loose.
Old Mar 11, 2014 | 04:58 AM
Patm-a32's Avatar
U have to ziptie them together on the one piece r34s i have hids in my one piece housings and i just zipped the connectors together mine wouldnt hold either... Also had trouble installing headlights but got them all snug
Old Mar 12, 2014 | 06:04 PM
maxim14212's Avatar
I did try to use the ziptie to hold the connectors but still not a proper connection. If I solder the wires what will be side effect of doing so. Will the lights remain on everytime or just when I turn the light on.
Old Mar 12, 2014 | 06:14 PM
I would use butt connectors personally unless you're good at soldering. It's so easy to get a cold joint and you will still have issues.
But no, they won't stay on all the time. They will only be on when you turn them on.
Old Mar 14, 2014 | 06:48 AM
Patm-a32's Avatar
^^ butt connectors will be ur best friend
Old Mar 14, 2014 | 08:04 AM
Quickywd01's Avatar
wyobbagy
Jan 3, 2023 12:03 PM
Hdnseek
Sep 9, 2015 05:55 AM
mpbclutch33
Sep 8, 2015 06:21 PM
jfl330
Sep 4, 2015 01:44 PM
