Loaded Suspension Jacking/Lifting Q
Old Mar 12, 2014 | 05:04 AM
Turbobink's Avatar
I'm trying to track down a front end noise and I need to get the front end off the ground.
However, I also need to keep the front suspension fully loaded as if the car was still sitting on the ground with wheels/tires in place but with the wheels/tires removed.
Do any of your guys have info on a spot beneath the front suspension members that can be used to raise the car while keeping the suspension loaded yet not causing any damage?
I thought about placing an appropriate length of 2x4 under the lower control arm right under the ball joint and raising from there ... but, I don't know.
Any takers?
Old Mar 12, 2014 | 05:45 AM
njmaxseltd's Avatar
I've jacked right from the control arm. Be very careful, it's not a very secure way to lift.
Old Mar 12, 2014 | 06:04 AM
dwapenyi's Avatar
The center crossmember is a jacking point.....so long as you have the beefy OEM piece. Some members doing radiator support fixes have used aftermarket crossmembers which are light and fragile.
Turbobink's Avatar
My plan would be to lift both sides simultaneously and at the same rate.
Old Mar 12, 2014 | 06:06 AM
Turbobink's Avatar
Understood ... but I need to keep the suspension under load.
Old Mar 12, 2014 | 06:15 AM
dwapenyi's Avatar
Ohhhhh, I see. Then LCAs like u said, or perhaps ramps?
jmlee44
Oct 2, 2022 02:13 PM
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
