P1105 Code.....need help
Old Mar 16, 2014 | 04:19 PM
jbanks1977's Avatar
I have this P1105 code that keeps setting off my check engine light. I have a subscription on All Data and this code doesn't even appear for this car. I have check all hoses and connections and I can't seem to track down the issue. My vehicle is a 1997 Nissan Maxima GLE, manual transmission. Was able to fix all the other codes already. If I reset the codes, the car runs fine. The light will stay off until I shut off the car and then when I turn it back on, a few secs later the check engine light comes back on. Anyone else have this issue and if so, how did you fix it?
Thanks for the help.
Old Mar 16, 2014 | 04:25 PM
CS_AR's Avatar
Possible Faulty Map/Baro Switch
1) Check to see if the fuse is good (fuse number 17 10 amp fuse)
2) Map/Baro Switch Valve - may need replacement.
Here's a thread on this subject below.
http://forums.maxima.org/4th-generat...-solenoid.html
Old Mar 17, 2014 | 12:48 AM
DennisMik's Avatar
I'm much less than impressed with All Data.
See page 277 is section EC of the Nissan service manual:
http://boredmder.com/FSMs/Nissan/Maxima/1997/EC.pdf
Old Mar 17, 2014 | 01:13 AM
dwapenyi's Avatar
Originally Posted by jbanks1977
...My vehicle is a 1997 Nissan Maxima GLE, manual transmission. ..
Maxima GLEs were automatic only. You either have a GXE or an SE. The SE had white faced gages (speedo, rpms, etc), rear spoiler, and foglights standard. A GXE could have some of that but most likely not the white faced gages. Which one is yours?
Old Mar 17, 2014 | 10:34 AM
vq4thgen4life's Avatar
OP, could have did a 5 speed swap....
Old Mar 17, 2014 | 10:46 AM
dwapenyi's Avatar
Doubt it, cause if he did, figuring out this engine code CEL would have been child's play.
Old Mar 2, 2022 | 09:18 AM
ldempsey's Avatar
Thank you Dennis.. you picture sure helped. I enjoy the big right lable and the color coding.. That was a life saver since two solinoids are amost labeled alike, look alike, and appear to perform the same thing. Thank you.
bryants95max
Oct 2, 2015 12:52 PM
SSzretter
Oct 1, 2015 07:39 AM
MaximaSpd85
Jul 9, 2013 06:20 PM
IlyaK
Mar 3, 2009 08:39 PM
