Could bad fuel economy be due to worn out injectors?
Old Mar 20, 2014 | 02:31 PM
granturissimus's Avatar
My dad says so, but I dunno if that's true.
Old Mar 20, 2014 | 03:38 PM
chrome91's Avatar
if the O-rings are bad, yes. when the O-rings go bad unmetered air enters, the computer thinks youre running lean and adds more fuel to compensate so you run rich as hell and get bad MPG
Old Mar 20, 2014 | 07:02 PM
CS_AR's Avatar
How many miles does you Max have on it? Have you measured your mileage? Do you use premium fuel? Is the bad mileage in town or both highway and town?
Old Mar 20, 2014 | 07:20 PM
chrome91's Avatar
regular vs premium in a 4th gen wont matter
Old Mar 20, 2014 | 08:32 PM
Maxima 97 SE's Avatar
Atcually it will because its high compression vq engine and it will run and give you better milage if you run premium as it is designed for premium fuel and it even says it on your gas tank.
Old Mar 20, 2014 | 08:51 PM
Climaxx's Avatar
I did testing a couple years back and found I average 3 mpg more on premium than on cheap gas.
Old Mar 21, 2014 | 05:35 AM
njmaxseltd's Avatar
Unmetered air will trigger a lean code, not make you run rich. There are set limits to how much adjustment of fuel delivery to obtain correct a/f as reported by the o2 until an DTC is set.
There are many variables that effect MPG. Injectors would be the last place to look on these engines. Many on here have way over 200,000 miles on original FI that get upwards of 30mpg on trips. Self included...
What is your current gas mileage?
Fill up, reset Odometer, drive until empty, fill up again, same station, do not top it off. Read the gallons on the pump and the reading on your odometer. Now comes the tricky part, you need to do MATH.
Divide the miles driven by the gallons used. Report back.
Old Mar 21, 2014 | 07:45 AM
Quickywd01's Avatar
BkGreen97
Apr 2, 2016 05:47 AM
Excalibur23
Oct 13, 2015 04:33 PM
gustavison
Oct 4, 2015 06:50 PM
aminus21
Sep 12, 2015 04:53 PM
