Whistle
Old Apr 8, 2014 | 08:34 AM
alperry360's Avatar
Whistle
Hello everyone, I have a question. Does anyone know if the Egr would cause some type of whistling noise. I replaced my manifold gasket and when I took off the intake manifold the egr gaset came off. I put it back on and since then I have been experiencing a whistling coming from that general area. It anyone has a suggestions as to what would be causing this noise, as I am open for suggestions. Thank you in advance
Old Apr 8, 2014 | 10:58 AM
Slamrod's Avatar
Sounds like it could be a vacuum leak, if you are missing the gasket then that would be the first place to look. Did you use new gaskets for everything you removed?
Old Apr 9, 2014 | 06:26 AM
alperry360's Avatar
I used new gaskets in everything I removed except the EGR. I checked all my hoses and there are no leaks there. I think I going to replace the entire EGR and the gasket. I tried to clean the EGR, but that just made it worse.
homeyclaus
Sep 3, 2015 06:15 PM
MikeyMike
Mar 5, 2002 08:37 AM
bullseye
Dec 18, 2001 09:06 PM
Turbo95Max
Sep 30, 2001 01:43 AM
