wheel balance: tape vs. clip-on weights
Old Jan 20, 2002 | 07:01 PM
Lkldraw's Avatar
have people had more success with balancing
the wheels with tape vs. the inner rim clip-on weights?
in particular, people who have aftermarket rims.
Old Jan 20, 2002 | 07:13 PM
njmaxseltd's Avatar
Clip on weights on the inside of the wheel and stick on weights, hidden just inside the rim for the outside area. Keeps the wheels nice and clean looking. I even have my OEM rims balanced that way. A good tire guy should balance alloys this way.(IMHO) I've never had a shimmy or balancing problem with weights being applied this way. Who would want an ugly rim weight stuck to the side of your expensive alloys anyhow?
Old Jan 20, 2002 | 07:18 PM
Lkldraw's Avatar
so you use "both" inner rim clip on weights "and" tape weights?
i guess then you won't have a 6" long string of tape weights
on the inside of the spokes.
what you are really saying is that tape weights which are nearer to the centerline of the wheel make a difference to the balancing.
Old Jan 20, 2002 | 07:38 PM
DanNY's Avatar
Ad·min·is·tra·tor
Re: wheel balance: tape vs. clip-on weights
it doesn't make a difference. both does the job of balancing the wheel.
the clip on is more "efficent" because it's at the very edge of the rim
the stick on is easier on the clear coat and does not gouge the alum wheel but i believe you have to add slight more to compensate the weight being behind the the rim.
if you rim is so out of balance that you can't balance the wheel w/ stick on or clip on weight then i would consider getting another rim.
Old Jan 22, 2002 | 01:33 PM
ciscov's Avatar
tape weights just give it a cleanner look!!!!
Old Jan 22, 2002 | 03:55 PM
Micah95GLE's Avatar
I always use stick-on weights. Clamp-on weights will destroy the finish of the wheel.
jsmith24
Feb 1, 2016 12:35 AM
Junebug1701
Sep 25, 2015 01:54 PM
mpbclutch33
Sep 21, 2015 01:54 PM
dcam0326
Sep 8, 2015 11:02 PM
