Engine missing/misfire.
Old Apr 17, 2014 | 08:42 PM
intimidator's Avatar
I have a 1996 Maxima when accelerating it would miss and when stopped in drive I feel like a bump like the engine about to shut off every few seconds.
I have a check engine light.
P0443 = EVAP Canister Purge Control Valve/Solenoid
P1400 = EGRC Solenoid Valve
Would any of those codes cause the miss?
Old Apr 18, 2014 | 10:00 AM
DennisMik's Avatar
Those codes usually will not cause the engine to miss or bump or what ever.
When were the spark plugs last changed?
What rpm does the engine idle at?
Old Apr 18, 2014 | 12:24 PM
4th gen maxi's Avatar
lol in fact a plugged egr will cause a bad studder when on decel.
Clean the tube and sensor going to manifold.
Sounds more like a bad iacv or bad coil.
Old Apr 18, 2014 | 12:58 PM
njmaxseltd's Avatar
A clogged EGR will cause nothing more then a check engine light and a slight decrease in MPG.
The bump your feeling is indeed a misfire. Usually caused by a coil pack, but could be a FI failing. Start by pulling the electrical connector off one coil at a time and see if you can locate the cylinder that's acting up.
Old Apr 18, 2014 | 06:29 PM
What is the best way to test the coil packs?
I had the iacv replaced about a year ago but I am now hearing a ticking sound coming from it.
Old May 1, 2014 | 12:53 AM
Could a bad a fuel injector cause the problem; even though I not getting a check engine code.
Old May 1, 2014 | 02:30 AM
DennisMik's Avatar
Fuel injectors will not cause a check engine light. While you could have a bad fuel injector, it is more likely a coil pack problem.
But you need to figure out which cylinder is having the problem. njmaxseltd suggested you unplug the coil pack one by one. Have you tried that yet?
Old May 1, 2014 | 05:12 AM
I did unplug each coil pack and it checked out ok. Not sure what to check next?
Old May 1, 2014 | 08:32 AM
CS_AR's Avatar
How many miles do you have on your Max?
Old May 1, 2014 | 11:07 AM
150000 miles.
Old May 1, 2014 | 11:34 AM
Maxima 97 SE's Avatar
P1400 = EGRC Solenoid Valve. These codes will causes a misfire because the valve is part of the egr system and it control the vacuum system as we'll and if it is not functioning right it will cut off the air that goes to the egr and the rest of the system which will causes the car not burn the fuel correctly because the air fuel ratio is disturbed. Get that egr solenoid fixed. It has two vacuum pipes going to it. Here's a pic of it, also visit this link it lists all the symptoms of a bad egr solenoid and lists all the symptoms that you are having. http://www.ehow.com/facts_7225011_eg...n_.html#page=2
Old May 2, 2014 | 08:59 AM
tech_auto's Avatar
Those symptoms are similar to mine. I had to replace two coil packs within six months.
Old May 18, 2014 | 08:48 PM
Replaced EVAP Canister Purge Control Valve/Solenoid and EGRC Solenoid Valve and nothing changed. Could it be the fuel pump?
Old May 18, 2014 | 11:44 PM
Here's how I fixed my cylinder misfire. I changed the crankshaft position sensor that hooked up to the transmission and the spark plug for cylinder 3 that only had 4,000 miles on it which was double plat ngk. One year ago I had a cylinder 5 misfire code and it wouldn't go away and I changed the crankshaft sensor on the tranny and it was gone. The misfire only occurred when changing gears and at highway speeds but not at idle and I even changed the maf and that didn't help and the coils were all oem Nissan brand new from about 5,000 miles ago. So the conclusion here is that its not always a bad coil, maf or etc. it could be tiny little things like the crankshaft sensor or a spark plug that could be new but still bad some how. Since the crankshaft sensor is responsible for engine timing, the driver may experience engine backfire or irregular rpm function, if the vehicle starts at all.
Read more: http://www.ehow.com/about_5860665_ba...#ixzz2zTIZR81N
Old May 19, 2014 | 04:49 AM
CS_AR's Avatar
Broken injector pintle caps were causing random misfires on cylinders 5 and 2 in my 99 Max SE 5MT. I went back and looked at the old plugs and two were discolored compared to the others but I didn't think about injectors at the time.
How many miles do you have on your 4th gen?
Old May 19, 2014 | 11:53 PM
The mileage is 150000. Did you get a check engine light with the injector problem?
Old May 20, 2014 | 12:26 AM
CS_AR's Avatar
No Check Engine Light (CEL) codes specific to the injector issues. The injectors all Ohm tested within spec. The only CEL codes appeared on Cyl 5 and Cyl 2 were the misfire codes. I could clear the codes and it would run for a while then Cyl 5 would re-appear at idle more frequently than Cyl 2.
I tried moving the coils, new plugs, I replaced both CKPS with my perfectly good running I30 and still had a misfire issue.
I had the car at the dealer for almost 2 weeks and paid them $750 to tell me I needed a new engine for $8,400 to correct the misfire issues. I had to pay to have the car towed home where I took it apart and found the broken pintile caps and clogged/burned up cats.
I'll find a thread by "The Wizard" who found similar broken pintile caps. The Wizard sent his injectors to Deatsch Werks in OKC for new pintle caps, screens, o-rings and injector service and testing.
Depending on the age and mileage of our cars, we are starting to think an injector refresh kit might be a good mid-life maintenance item to install new injector pintile caps, screens, and o-rings.
If you have corrected the issue, then I would drive it a while to see how it goes. If the problem returns, there is not much remaining but something like the injector issue.
Check out this thread.
http://forums.maxima.org/4th-generat...ite-smoke.html
Old May 20, 2014 | 01:12 AM
Thread Tools Search this Thread Display Modes
03-25-2014, 09:22 PM #1
Maxima 97 SE
Garage is empty, add now
Nissan Maxima 97 SE
Points: 1,812, Level: 25
Activity: 33.3%
How I fixed my hard start issues: Finally
Ok this how I fixed my hard start issues with my Nissan maxima 1997 se automatic. I had to make sure my fuel injectors were good and they were but not the pintle caps that hold the O-rings together. The pintle caps were cracked and as soon as I Fixed those the car would start right away on every start. Then later on car would still start on the fisrt start but as soon as I would start after an 1-2 hours the car would start but would almost stall but it wouldn't and I figured it had to be a fuel pressure problem and it was. The fuel pressure regulator was good as I had a new oem one on. That left me to the fuel pump. I had put a an oem fuel pump that had 129,000 miles that I thought would run good but now I know no matter how many miles the pump has it can still be bad and it was luckily I had a oem Nissan fuel pump from 1995 Nissan maxima with only 176,000 miles and now no more problems. its been two weeks and now im finally happy that I don't have to work on my car anymore or worry about the starting because after 1 whole year it's finally gone. Its gone and now I am getting more gas millage as I filled my tank with premium 91 and I still a half of a tank with 180 miles. Im hoping to get at least 300 miles with a full tank of gas now that the car has no problems with 303,396 miles on it. Now if I can get 300 miles from my maxima now where I used to 260 miles with a full tank that would kick *** and I would be happy.
Old May 20, 2014 | 01:18 AM
For you all you need to do is take out all three of the front injectors and check to see the condition of the pintle caps of the injector. Those are the easiest to reach and a quick fix if it's only the front injectors. It will give you a good clue of where to start from. But I kind of have a doubt that it's your fuel injectors because i took some out of a Infiniti i30 1997 with 150,000 miles and the pintle caps were in good condition. But it's always good to check. If u do decide to take them out makes sure you properly seal and put them back in and push it all the way down other wise you will have a pressure leak and will causes starting problems.
Old Jun 18, 2014 | 09:48 PM
Changed the injectors and still the same problem nothing changed. Not sure what to look at next?
Old Jun 19, 2014 | 12:52 AM
did you change the sensor in the picture next to the spark that i had posted. If not do that as i have already stated that it will cause misfires if it goes bad.
Old Jun 23, 2014 | 12:00 AM
I changed the sensor in the picture still the same problem.
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
