Years of Procrastinated Maintenance.
Old 04-22-2014, 11:50 AM
matts95max's Avatar
Ok so Ive had my maxima since about 2006-2007 and bought it as a shell to swap good parts from my totaled maxima into. Well over the years, the list of things requiring TLC or needing replaced all together has added up and I'd like to start fixing some of them. The car has over 300k miles on the body now and I got 464 hand calculated miles on my last full tank of gas, or about 30.5 miles per gallon. I paid cash for it, insurance is affordable, and its been reliable so I plan on keeping it and fixing some of the issues. Here's a few to get started
            Thanks,
            Matt
            matts95max is offline
            Old 04-22-2014, 12:07 PM
            dwapenyi's Avatar
            Originally Posted by matts95max
            ...I would also like to build some type of support as I often carry a lot of weight in the trunk and previous boards en up bending. Any ideas for a design that leaves easy access to the spare tire?...
            Talk to djfrestyl;
            http://forums.maxima.org/general-max...tion-sale.html
            For the rear, if I go with the i35 folding seat back, I thought about removing the thin metal shielding/support to give more functionality to the fold down seat back. Will this be possible?
            Not sure how doable it is, but once done you will probably experience more road noise coming into the cabin, and also develop more squeaks and rattles. My car right now has some squeaks in the trunk from the spot welds. I drench the area just above the rear shock towers with WD-40 and the sound disappears for a short while. Of course my car stinks for a little while too
            • My rear windshield defroster doesnt work because I sliced the lines removing tint and I planned on getting a rear windshield from a salvage yard and having a company install it for me. This a good idea? Will companies install used windshields?
            You should be able to repair the lines. If not, Salvage or perhaps even a new replacement would be the second option. The salvage and new prices may be comparable now that the car is old.
            dwapenyi is offline
            Old 04-22-2014, 12:19 PM
            dwapenyi's Avatar
            Also, the 5th and 5.5 gen seats are not a straight swap.
            dwapenyi is offline
            Old 04-22-2014, 12:29 PM
            5th gen dd's Avatar
            And if you do go this route avoid 5th gen seats for their crappy vinyl inserts that have all deteriorated already. 5.5 seats are far superior. Can't speak for the difficulty level to get them in a 4th gen though.
            5th gen dd is offline
            Old 04-22-2014, 12:39 PM
            matts95max's Avatar
            ok so 5th gen seats avoided. Ill look for i35, 5.5 gen, or 350z. What should I expect to pay for 2 front seats?
            Ill check out that permatex defroster line solution, thanks! and I really like the spare tire solution you linked.
            Im not looking for more road noise, but am very interested in getting the folding seat back to work properly.
            Also, I read that the seats aren't a direct swap and that swapping rails and stuff will be needed. Im OK with that.
            Thanks for the input!
            Old 04-22-2014, 01:15 PM
            5th gen dd's Avatar
            I paid $400 for a full minty set of I35 heated seats. He wanted $300 for just the 2 fronts.
            Old 04-22-2014, 04:32 PM
            Patm-a32's Avatar
            The plastic clips u can buy from nissan, under 10$ my spoiler snapped off like a few months ago and i got the clips
            Patm-a32 is offline
            Old 04-22-2014, 05:26 PM
            Patm-a32's Avatar
            And i have subs in my trunk i kept bending boards i chanfed in my trunk, just fit some plywood in the trunk and no more bending and still have acess to the spare
            Patm-a32 is offline
            James92SE
            142
            01-02-2024 09:23 AM
            captchaos
            03-15-2016 12:18 PM
            JoshG
            51
            09-21-2015 10:41 PM
            Socalstillen
            09-20-2015 11:46 PM
            pears
            09-18-2015 05:25 AM
            Quick Reply: Years of Procrastinated Maintenance.
