Electronic Motor Mounts
Old Apr 25, 2014 | 08:15 AM
PH98I30's Avatar
Searching through the forum, I noticed that the electronic motor mounts in the front and rear can leak and fry the computer unit if they rupture. I want to unplug mine and it looks like you have to remove the air intake unit to get to the plugs. I see the wires coming out of the mounts but then they disappear up under the air filter assembly. Is there any problem in just cutting the wires and taping off the ends of them? Eventually when they leak, I will replace them with the MT mounts.
Old Apr 25, 2014 | 08:29 AM
Fakie J Farkerton's Avatar
You're thinking of 5th gen having the short out problem, not 4th gen.
Old Apr 25, 2014 | 09:27 AM
PH98I30's Avatar
Cool. So then I don't have to worry about the computer frying. Thanks for the answer. They aren't leaking or making noises yet, so I am good so far.
Old Apr 25, 2014 | 09:29 AM
You're welcome.
When they do get old and you want to replace them, a good upgrade is energy suspension.
You will need non-electric/manual mounts for those though, but you can deal with that when the time comes.
Old Apr 25, 2014 | 09:31 AM
PH98I30's Avatar
Thanks for the advice. You guys on this site are great. I will take that advice.
Old Apr 25, 2014 | 09:46 AM
Glad to get positive feedback.
Need more positive org'ers like you.
Tell your friends to get Maxima's and join.
Old Apr 25, 2014 | 10:08 AM
PH98I30's Avatar
I love this car. I bought it 3 years ago. It threw the knock sensor code & an O2 sensor code. The O2 code was from the tune up guy only hand tightening the spark plugs. When I torqued them to specs, the code went way. The knock sensor had a cracked housing, so I replaced it. Other than that, I 've only had to replace an alternator because the bearings went out at 129K on the clock. This car is great except for the ugly gold color, but I can live with that. Thanks for the help.
Old Apr 25, 2014 | 03:34 PM
Trini Boom's Avatar
I believe its only the front engine mount that is electric. The rear mount is not...and I do agree that champagne is not my favorite color in this car...
Old Apr 26, 2014 | 03:00 AM
maxinout93's Avatar
Will it make any difference if you swap the electric mounts for the non electric automatic mounts. Must do mine asap, car drives like crap!
Old Apr 26, 2014 | 05:48 AM
No difference except maybe a slight vibration in the wheel at idle.
Hardly noticeable.
Old Apr 26, 2014 | 09:05 AM
CS_AR's Avatar
Hardly noticeable.
+1 Hardly noticeable. Also, you can unplug the current electric mount and drive it around so see if you can feel any difference.
AaronL
Aug 8, 2020 10:31 AM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
knight_yyz
Nov 1, 2015 01:34 PM
