Does it look like my steering rack needs changing?
So stopped by the alignment by steering rack is leaky and needs to be changed at a cost of ~$850. Not quite ready to shell out that kind of money when I'm not absolutely sure, I decided to wait for a chance to get a second opinion. Well I've been looking at the steering fluid and it's not going down noticeably but the tie rod boots and surrounding areas are wet so I wanted to see what you guys think.
Driver side
Passenger side
Driver side
Passenger side
how long do you wanna keep the car?
i would just replace the inner tie rods and keep on cruisin
20-50 in parts - 1-2 hours in labor. hardest thing is getting a inner tie rod removal tool
Looks fine. I just replaced all the parts in my front end including new bushings for the steering rack. Rolling with 237k on my max. Just replace the tie rods ends and the boot, called bellows, and grease the rack. She will go much longer.
http://www.rockauto.com/catalog/more...555&cc=1211443
Seal Kit
http://www.rockauto.com/catalog/more...277&cc=1211443
2 inner tie rods
http://www.rockauto.com/catalog/more...321&cc=1211443
2 outer tie rods
http://www.rockauto.com/catalog/more...416&cc=1211443
2 boots
then change the fluid and you basically have a new rack...
Seal Kit
2 inner tie rods
2 outer tie rods
2 boots
I don't think you need to replace it. Mine has 305,000 miles and original rack plus my passenger side boot is broken like your and it's still running fine with no problems. I would just replace your driver side rack and pinion bushing which I did and it made it handle much better and it ran like new . The rack and pinion bushing are really important for the rack to run and do its job. Without them your handling would suck and the car would wonder all over the road.
Seal Kit
2 inner tie rods
2 outer tie rods
2 boots
Seal Kit
2 inner tie rods
2 outer tie rods
2 boots
Kev, I was looking at your sticky about the replacement of the rack and pinion. You noted that the majority of the 4th gen racks are leaking and wanted to know what leak determines that it needs replacing? Mine is leaking from where the steering meets the rack. This guy has pics of his not leaking but it has oil located where the inner tie rods are located. It doesn't look like tranny fluid though so its not leaking from in there or is it?
you dont have to change but if you're already inthere you might as well
So if I bought the seal kit, they can be replaced with the rack still attached to the car? Can anyone who has done a seal replacement pitch in?
lowpost99
Oct 26, 2025 06:53 PM
mikeg75
Nov 30, 2015 05:12 PM
