Major Suspension / Brake noise
Old May 10, 2014 | 11:52 AM
LuminousX's Avatar
About a month of 2 ago I pulled up in a small drive thru, with my radio down, and I could hear like a spring or something like that making a loud sound whenever I let go the brakes, and apply it, so I know it's the brakes, the next thing is, whenever I decide to take off from a red light hard then I should, I would hear like a crack or something like that, it started happening right after I had my Lower Control Arm replace, and I would hear the same sound in the back then I pull off, and the back of the car would drop back, then I keep getting a bumping sound around the passenger side suspension area, it would sound like it's coming from under the hood, but I know there's nothing other the hood that would be making that sound, and it started happening after I ran over a ramp on the highway around about 30-40 mph, on top of that I was told by my mech that (something link) that's the best I could come up with it, the name ends with Link, that's all I remember, and he said I should replace that the day I was doing the control arm, so I hope you guys could help me out, appreciate it.
P.S will any of this be able to get replace with basic hand tools, if I do buy parts to replace?
Old May 10, 2014 | 04:43 PM
bewrong's Avatar
Did it sound like 'Scott-Russell link'?
Old May 10, 2014 | 04:51 PM
LuminousX's Avatar
no I believe it was sway bar link or something like that
Old May 10, 2014 | 09:28 PM
bewrong's Avatar
Well, how's your sway bar link look? Torn boot?
Old May 10, 2014 | 10:30 PM
LuminousX's Avatar
never really got around to looking at it, more of the time when I'm parking I'd hear some popping sound maybe once or twice
Old May 11, 2014 | 11:45 PM
LuminousX's Avatar
can anyone give me some answers to my questions
Old May 11, 2014 | 11:58 PM
Fakie J Farkerton's Avatar
Check your motor mounts.
Old May 12, 2014 | 01:42 AM
LuminousX's Avatar
my engine doesn't jerk moving from gear to gear other than normal stuff
Old May 12, 2014 | 11:39 AM
Patm-a32's Avatar
Check the pin rod going through the lca bushing. a few turns on the bolt and u should be good. U should re tourque every thing on the lca after a few days of driving on a new one. I just got through with this issue if it got loose or something it will cause a bit of play in the arm and causing your noises. Hope this helps!
Old May 12, 2014 | 12:45 PM
LuminousX's Avatar
I see, I did read somewhere on the org that users say it's better if you push down on the car so everything can set before you tighten everything up, someone stole my tool set out my car so Ima have to buy a new one, it sucks not having any form of tools to work with, but I will do that, it does sound like something is lose
Old May 12, 2014 | 07:30 PM
Patm-a32's Avatar
Its a locking nut on the pin rod and the nylon stretches after its fitted on the bolt also so i torqued mine down anyways after a week just cause i was told to and it ended up getting rid of my noise
05RLS2
Sep 27, 2015 09:24 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
lrb6805
Sep 17, 2015 04:49 PM
thenewguyy
Sep 12, 2015 11:12 AM
A32goldylocks
Sep 2, 2015 06:39 AM
