Front Sway Bar Removal/Replacement
Old May 14, 2014 | 09:27 AM
ThaMax's Avatar
I'm fairly certain I recall a how-to thread with pictures which discussed this, but I am having trouble finding it and wanted to review it.
Most of the search results I've come across so far pertain to the sway bar end links, ES sway bar bushings or RSB.
I imagine the job may be similar to removing the power steering rack (drop y-pipe, remove cross member & front/rear motor mounts).
The reason I am looking for this is there are some isolated rust issues with my sway bar that are causing incorrect bushing fitment/reduced life. This could be solved with a junkyard replacement depending on the scope of the project.
Old May 14, 2014 | 09:58 AM
PowerTotheMax's Avatar
I dont recall dropping the crossmember or ypipe before removing the sway bar when I did my steering rack(i did later however, to do the rest of the steering rack job). I just twisted and pulled the sway bar around til it came out; Although it would be easier to do so first.
Old May 14, 2014 | 11:19 AM
ThaMax's Avatar
Hmm, interesting. Well if careful twisting and pulling is an option, I may try and develop a removal method in the junkyard next time I go.
Thanks for the feedback PowerTotheMax
Old May 17, 2014 | 01:42 AM
CMax03's Avatar
The swaybar might be removeable after the rack and pinion is removed...you won't get it out with the rack and pinion installed!
lowpost99
Oct 26, 2025 06:53 PM
adamgalazka
Feb 5, 2023 08:24 AM
wyobbagy
Jan 3, 2023 12:03 PM
alahjahwan09
18
Sep 21, 2015 09:12 PM
jfl330
Sep 4, 2015 01:44 PM
