96 maxima where to buy tierod washers
Old May 20, 2014 | 05:05 PM
fullauto's Avatar
Does anyone know where to buy just the stupid washer that comes with a new tierod? I've looked everywhere I can. I've tried all the usual spots, Autozone etc. I already bought the new inner & outer and changed them out. But it didnt solve the problem, Im still getting a metal on metal bang every time I hit a bump. The 1st time I just changed them out but still had the problem. So, I just re did today but this time I used locktite & a torque wrench. I torqued the inner tierod to 70lbs & the outer @ 30lbs. Im fairly confident I did it right both times I just dont trust that washer. If any1 can help me either find the new washer or just throw me some ideas on what else it could be.
Old May 20, 2014 | 05:20 PM
njmaxseltd's Avatar
What washer? The only washer type item is on the inner tie rod. Looks more like a clip, you should have gotten one with the new part. I highly doubt that the lack of that part would cause and suspension noises.
If you've swapped the parts 2x and you still have the same issue, look elsewhere for the problem. The tie rods aren't causing the bang. Start looking at the strut assembly, sway bar and lower control arm bushings.
Old May 20, 2014 | 08:19 PM
maxinout93's Avatar
Yes i agree tie rods only control the steering, maybe look at your struts
Old May 22, 2014 | 03:01 PM
Quickywd01's Avatar
1997 NISSAN MAXIMA 3.0L V6 : Suspension : Stabilizer Bar Repair Kit
$2.17
http://www.rockauto.com/getimage/get...K90128_TOP.jpg
Old May 22, 2014 | 05:10 PM
Alaskus's Avatar
are you referring to the inner tie rod locking washer? I didnt get those either and simply put thread locker red on it - i haven't had any issue in eight(ish) months.
if I die in a horrible fiery wreck ill update my post.
Old May 25, 2014 | 06:28 PM
CMax03's Avatar
You can try to order them from the dealer:
http://www.courtesyparts.com/49635m-...-p-134299.html
Old May 25, 2014 | 07:37 PM
Fakie J Farkerton's Avatar
ah2002
Mar 9, 2016 01:42 PM
jchronis2552
Aug 13, 2015 07:48 AM
Wolvee
Aug 11, 2015 12:24 PM
MikesChevelle
Aug 6, 2015 11:36 AM
