Prepping my 97 for a de-k motor
Old May 23, 2014 | 07:25 PM
ghostI30's Avatar
I have a de-k motor from an previous car that had the swap but i want to start the swap from scratch so i know exactly what needs to be done. I believe the motor i have is good but how can i guarantee its ready. I already have a vafc2, aftermarket fuel pump, what else do i need for everything to be right
Old May 23, 2014 | 08:18 PM
JvG's Avatar
JvG
This is the perfect opportunity to replace any seals that might be a problem to fix once the engine is in the car. Rear main seal, valve cover, etc. Might as well do sthe spark plugs, anything you can think of that might be PITA in the future.
Fakie J Farkerton's Avatar
http://forums.maxima.org/4th-generat...vi-manual.html
Please search the stickies.
Old May 23, 2014 | 08:22 PM
Don't touch the rear main unless it's for sure leaking.
Half moon seals, yes; RMS hardly ever.
Shout out to Schmelly.
Old May 23, 2014 | 08:30 PM
JvG's Avatar
JvG
Fakie, I defer to your expertise. I have read about the half moon seals. I should remember that should i need to replace my clutch someday. I normally like to replace the RMS at that point, just because it is good preventative maintenence.It appears that I should replace the half moon seals as well on the Max when the time comes.
Old May 23, 2014 | 09:22 PM
You can't properly do the rear main without dropping the upper oil pan anyways.
Old May 23, 2014 | 09:30 PM
I<3 A32's's Avatar
check the valve clearance see if its within tolerance change water pump timing components if needed
Old May 24, 2014 | 01:53 AM
dwapenyi's Avatar
.... anything you can think of that might be PITA in the future.
If you plan on installing headers do them now before the engine goes in.
Old May 24, 2014 | 03:30 PM
asand1's Avatar
Tear timing cover o-rings.
Old May 24, 2014 | 05:42 PM
ghostI30's Avatar
Thanks guys ...I want to do this the right way, i also have a jwt 96 ecu
Old May 26, 2014 | 05:28 AM
ghostI30's Avatar
Bump
Old May 26, 2014 | 05:40 AM
Originally Posted by ghostI30
Bump
Did you read the link I posted?
Why EXACTLY are you bumping?
Old May 26, 2014 | 05:58 AM
ghostI30's Avatar
No i didnt but i will now...
AaronL
Aug 8, 2020 10:31 AM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
knight_yyz
Nov 1, 2015 01:34 PM
