Left tail light problem.
Old May 28, 2014 | 10:54 AM
Johnny9595's Avatar
Change the bulb when headlights are on they are on but once brakes are applied the secondary filament doesn't light up. Bought new bulb and everything swapped the bulb to other side and no problem. Anyone know the fix rather not get take to a mechanic or get pulled over.
Old May 28, 2014 | 11:13 AM
Amerikaner83's Avatar
bought 1157 bulbs not 1156, correct?
Check the wiring at the connector. Maybe grab your voltmeter and have a friend push the brakes while you measure for voltage.
Old May 28, 2014 | 11:16 AM
lux97Max's Avatar
Check your fuses
Old May 28, 2014 | 11:25 AM
Originally Posted by lux97Max
Check your fuses
both brake lights operate on the same fuse...a fuse would show a problem in the right brake light as well, and OP has indicated the right side works normally.
Old May 28, 2014 | 11:47 AM
lux97Max's Avatar
it wouldn't hurt to check.
Old May 28, 2014 | 04:26 PM
JoshG's Avatar
when my tail lights went out, I just went to autozone..told them what car i had.. gave me the right bulb, took to mechanic, took him 5 minutes and then paid 5$ for it. donee
but yea, there could be other problems like fuses and such like what people are saying above.
Old May 28, 2014 | 08:21 PM
dwapenyi's Avatar
I have the same/similar problem. The left hand brake bulb will die every 3 months or so...every time. Fuses are not the issue. I'm about to replace the taillight socket(s) on the left side as I think there may be a loose connection causing the failure.
Old May 28, 2014 | 09:24 PM
Johnny9595's Avatar
Where can I find another socket other than the junkyard.
Old May 28, 2014 | 10:33 PM
Fakie J Farkerton's Avatar
Don't fear the junkyard, they can be your best friend.
You can message sellers on eBay that are selling used parts from the same type car and ask them.
I got lucky with an eBay seller selling a used 6 speed and got the shifter and cables for cheap, so it's possible.
Old May 28, 2014 | 11:06 PM
dwapenyi's Avatar
I wonder if this is something that could be unique to I30s?
Old May 29, 2014 | 03:19 AM
maxinout93's Avatar
I remember I had to replace the pass rear brake/tail light socket on my max
mvm062
Nov 30, 2020 09:00 AM
dvcamp
Sep 18, 2015 10:17 AM
Maxima30
Sep 7, 2015 06:13 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
Pnjboyzz
Sep 4, 2015 09:04 AM
