Alignment Suspension Tire wear problem
Old Jun 11, 2014 | 10:34 AM
PH98I30's Avatar
Hi Guys. I have a 98 I30 with 133K on the clock. Yesterday I got a nail in my tire and went in for a tire repair. The guy tells me my tires are worn out and I need 2 new front tires. They are wearing on the inside and out side at the same time. I keep them inflated at 30-32 PSI. I run stock P205-15's. These are 40,000 mile warranty tires I have only put 5,000 miles on. Even the middle is wearing out almost to the wear bars. So, I want some opinions as to the problem being the suspension or alignment. I can drive the car 100 yards down a straight street and it will not veer to the right or left. It goes straight.... please help.
Thanks, Phil
Old Jun 11, 2014 | 11:15 AM
deathwobble's Avatar
Just because a car doesn't pull, doesn't mean the alignment is not jacked up or there are no bad parts. Caster can be bang on making the car go straight and the toe or camber can be off, and it only takes about .5 degrees out from what the manufactur specs are to cause tire wear. Take it to a shop you trust with a alignment rack, have them shake the front end down and if it's all tight then check the actual alignment.
djfrestyl's Avatar
Suspension Yoda
Even wear on both inside and outside? You're underinflated. 30-32psi is low.
Old Jun 11, 2014 | 11:22 AM
PH98I30's Avatar
The tire recommendation is 29psi. What do you recommend. I do like running overinflated but usually on long trips.
Old Jun 11, 2014 | 11:27 AM
Amerikaner83's Avatar
I stick to upper 30s on my tire inflation. just checked yesterday as a matter of fact, I'm at 38PSI on my Continentals.
Old Jun 11, 2014 | 11:32 AM
djfrestyl's Avatar
Suspension Yoda
34-36psi typically. Check the sticker on the inside of your door jamb.
Old Jun 11, 2014 | 11:57 AM
PH98I30's Avatar
The door jamb sticker says 29F & 29R which I always thought was low. I said earlier that my tires only had 5,000 mi on them but I forgot the 1. It's actually 15,000 mi, which is still too low to be wearing out.
Old Jun 11, 2014 | 12:02 PM
djfrestyl's Avatar
Suspension Yoda
There's only one way tires will wear evenly on both the inside and outside - underinflation.
Old Jun 11, 2014 | 12:06 PM
PH98I30's Avatar
Thanks. I will crank up the tire pressure to 38 and get an alignment check this weekend.
Old Jun 11, 2014 | 12:16 PM
djfrestyl's Avatar
Suspension Yoda
38-40 is high, but that might help to even out the wear on your tires
Old Jun 11, 2014 | 01:10 PM
asand1's Avatar
I always run 40psi
Old Jun 11, 2014 | 01:31 PM
PH98I30's Avatar
Thank you asand1. I always respect your opinion as well as some others. We have an air compressor here at work. The psi has already gone up.
Old Jun 11, 2014 | 01:35 PM
njmaxseltd's Avatar
Even the middle is wearing out almost to the wear bars..... please help.
Thanks, Phil
How many miles were on the tires you took off before these were put on?
They should be replaced free of charge or at least pro rated 5K miles. Got back to the place you purchased them from. What brand are they?
To chew up a set of tires in 5K miles you are either doing serious burn outs, aggressive driving or your front end is completely screwed up to the point you'd have a pretty noticeable drive-ability problem.
Or the tires are just junk...
Old Jun 11, 2014 | 01:38 PM
he meant 15K, and corrected in a later post
Old Jun 11, 2014 | 03:36 PM
njmaxseltd's Avatar
Missed that post!
Still evenly worn out at 15k miles on a 40k mile warranty, go back and get them replaced or consider putting a higher mileage tire on the car.
What brand and rating (H,R,Z?) are these?
Matt93SE
May 24, 2019 02:58 PM
Roymg
Sep 3, 2018 05:10 AM
homeyclaus
Sep 3, 2015 06:15 PM
