95 nissan maxima no cel when turn on key
Jul 3, 2014 | 10:14 AM
hey guys, ok now my maxima dont have a cel light on even if i turn on the key.
before i change out the motor wiring harness and the driver side wiring harness. i put the engine back in and i don't see a check engine light lid up at all.. any suggestion on what i should check out next.. im pretty much stuck at this time. the car does crank but never turn on. letting you guys know my car is a 95 and i
am using the 97 nissan maxima harness. the motor is also a 97 and so is the ECU.
all the light bulb are new. i even try changing out the ecu and still no cel light. not sure if the ecu needs grounding or what. i just lay it under the dash.
my car was running and the cel is on when i did the swap. i also rebuilt the motor with new seal and redo the timing on it since the motor was out of the car.
basically i bought a 97 max with no title and swap it into my 95 max. the guy that had the 97 max said that it was a running car, he just dont have a title for it. now when i crank to the car it does a loud poping backfire. but yet no cel light.
Jul 3, 2014 | 10:20 AM
Check the bulb.
Jul 3, 2014 | 10:27 AM
Yup, check out the most obvious thing first. The light bulb...
Jul 3, 2014 | 10:30 AM
blub are new and good
Jul 3, 2014 | 10:34 AM
Ok. Did your CEL work before you swapped in the 97 motor, harness etc?
Jul 3, 2014 | 10:40 AM
Quote: hey guys, ok now my maxima dont have a cel light on even if i turn on the key.
If you ask me cel's are over rated anyway!
