How to fix dim headlights?
Old Aug 3, 2014 | 05:45 PM
evintho's Avatar
On my '99 GLE I don't think it's a voltage issue. The lights don't get dimmer as you roll down the windows or anything of that sort. They're just not very bright. When driving at dusk I always have to ask my wife 'are the lights on?'
You can't really tell! You can see when it's dark but they could be a whole lot brighter! Is this a common problem? Are they just getting old? Am I just getting old? Would upgrading to higher end bulbs solve the problem? Any help is greatly appreciated!
Old Aug 3, 2014 | 06:12 PM
If you're headlights are hazy, get and do this:
This is sold at Amazon, Autozone etc.
Then go to Autozone and get the brightest Silverstar bulbs available (there are 3 tiers, go for the brightest and most expensive). Each bulb is $25.
Those two things will make a big difference. That's what I did any way and now I can see again!
Old Aug 3, 2014 | 06:35 PM
CS_AR's Avatar
+1
Meguiars really works magic to make headlight lenses look like new.
Check out this video.
http://www.youtube.com/watch?v=Zw5KSum28dc
Old Aug 3, 2014 | 08:55 PM
Amerikaner83's Avatar
more than 25 bucks, but yeah, the SilverStars are good. Be careful to not get your bare fingers on the bulb itself.
I do the 3M kit instead of the Meguairs above, but same basic thing.
I just did mine, this pic is before and after (but I wasn't done with the buffing "after".
Old Aug 4, 2014 | 01:11 PM
bumpypickle's Avatar
OP I changed my head lamps for cheap off of ebay. Plus some certain sellers will include a new set of headlights with the lamps. (Mine did) pm me for a link if you'd like.
Old Aug 4, 2014 | 11:09 PM
evintho's Avatar
Thanks for all the replies!
I bought a headlight restoration kit. The Meguiars Heavy Duty kit was $30. Right next to it on the shelf was a Turtle Wax kit on sale for $8.99. It had the same basic ingredients, sanding pads, compound, sealer, etc. I went cheap but it made all the difference in the world! The polycarbonate lenses are now crystal clear and the headlights very bright! Now I can see where I'm going! Driving down to LA tomorrow night. Should be a good test!
Old Aug 5, 2014 | 06:39 AM
Xero93's Avatar
How long does this sort of thing last? I've heard that once you eat through the top protective layer of the headlights, they will tend to get dull much faster. I'm also suspicious about the headlight "sealer" spray that you can buy. How much protection could a spray really offer? I've been doing some googling around about possibly spraying the headlights with some clearcoat after restoring them. It seems like people have long-lasting results doing that.
Old Aug 5, 2014 | 06:53 AM
Fakie J Farkerton's Avatar
IMO after the original UV coating is gone they will need polished about every year depending on the conditions they are subjected to.
Old Aug 5, 2014 | 09:55 AM
NissanNismoZ's Avatar
I did this on a 94 Nissan Quest, it had really hazy headlights, and if you're really tight on money, baking soda and water, mixed into a thick paste works the same, with lots of scrubbing, I had them looking nearly new in about 30 minutes, and how I kept it from coming back? Sprayed plastic clearcoat over the lenses and so far, in two years, it hasn't came back! Hope this helps!
Old Aug 5, 2014 | 10:22 AM
There's only one way to restore headlights PROPERLY..
http://m.my350z.com/forum/showpost.p...60&postcount=1
AaronL
Nov 15, 2020 11:52 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
kjlouis
Sep 14, 2015 11:22 AM
Hdnseek
Sep 9, 2015 05:55 AM
mpbclutch33
Sep 8, 2015 06:21 PM
